Serpent 710
Re: Roll Center position question
Originally posted by kreidel
If some wrote their Roll-center position upper on the setups sheet as : low inner, would that be the UTI or the UBI position that is explained in the setup book?
UBI would be top (up) inner.
UBO would be bottom (low) outer and UTO would be top (up) outer.
Originally posted by FW05R
So you think this is a good engine to race with?
my LHS has 3 of them currently in stock I am currently debating whether to get this engine http://www.nitrohouse.com/images/NovaRossi-TSR3.jpg
or the Novamega?
or the Novamega?
which one would you buy D if you were in my shoes
Re: Re: Roll Center position question
Originally posted by InitialD
That would be UTI (stock) or bottom (low) inner.
Originally posted by GlennCauley
Hi Eddie,
Nah, I am not worried about him cheating. I know he would probably kick my a** with any car. His is not the only NTC3 out there... all the NTC3 drivers should be aware of this insert thingy. Don't want to have anyone inadvertantly caught with their pants down due to an oversight. Especially if they go to a larger race where rules are more rigidly enforced.
Hi Eddie,
The one you were asking is a 5 port engine. Would that be legal to race with at your track?
That's a Top 3 port engine equivalent to the Novarossi 3 port NS or NSR. That would be a good engine.
Depends on my question earlier. I hope you realise that you're asking about 5 port Novamega against 3 port Top / Novarossi engine...
I use yellow all around predominantly. I think Julius uses red and when traction goes down, yellow all around. One time, I think he used red rear and yellow front in his setup. This he used with the UTI / LT rear roll center and highest front roll center. He says it keeps the rear in shape on fast sweepers. I tried yellow front and rear red and the car had a lot of on power steering. That was on my diff setup. The rear wasn't slipping at all.
I'm going to stand up the shocks a little more in the rear and see how it goes.
BTW, I'm currently using 4x1.2 mm pistons with 40wt Serpent shock oil front and rear. I believe Julius used 5x1.2 mm pistons with 50wt Serpent oil front and rear.
I am running whites on Front and yellows on rear, want to try yellow and red. I have not yet played with the shock holes or weight and only running standard. Not using ther front sway bar either. Did you find a big difference when changing to 1.2?
My Shock pos is 3, on the rear, made the car feel fantastic steering wise, I was suffering for a little steering. Made a big difference in the fast corners
Here is a crude picture of a on/off switch mount I made today.
Steering servo rod clearance
Have anyone had any problems with the steering rod hitting the
belt up front or should I get another servo arm for more
clearance...
clearance...
Re: Steering servo rod clearance
clearance...
clearance...
BRACKET MIDDLE SHAFT ALU
The BRACKET MIDDLE SHAFT ALU has arrived! Part number is 802155.
I not alble to connect my DV-camera to my PC, but it looks sweet
Also i forgot to measure the weight, but from what i've heard is that it isn't much heavier than the plastic one (about .8 gram i think!)
Re: BRACKET MIDDLE SHAFT ALU
Re: Re: BRACKET MIDDLE SHAFT ALU
Originally posted by PSI Racing
What color did they make it?
Originally posted by Eddie M
I don't realize there is more NTC3 at our track? I thought most of the cars are Mugen or Serpent...
For other ideas, see my article at:
http://www.mytsn.com/publ/publ.asp?pid=9994
