Serpent 710
Old 05-19-2004, 04:21 PM
  #10816
cox049's Avatar
Originally posted by jhigga15
Any seggestions on a radio...under 300...Please
JR XS3
Oh, and Welcome to the Serpent world!
cox049 is offline
Old 05-19-2004, 05:27 PM
  #10817
KevinS's Avatar
www.rc-mushroom.com has the 3PK for $250 (metallic) and $275 for the black metallic. You can probably get one shipped to you for under $300.
KevinS is offline
Old 05-19-2004, 05:33 PM
  #10818
rcpanama's Avatar
Originally posted by cox049
Amigo Panama I have a question about that return spring in your brake link... aren't you braking at the same time as accelerating?? The brake lever applies the brakes when pulled and also when pushed… see what I mean
OK when you accelerate your are pushing the return spring and when you brake you not pushing the spring, now when you lose power (battery) the return spring will push the servo arm to the minimum acceleration or idle, which is what you are looking for.
I had already two experiences with batteries and it had worked perfect.
On the Impulse I have it the other way but it is the same, now because I do not have a digital servo on the Impulse the servo it is not as soft as the digital when no power is apply.
rcpanama is offline
Old 05-19-2004, 06:21 PM
  #10819
InitialD's Avatar
Default Re: Re: Question
Originally posted by Fernando_M
I have seen the same problem with the 17/61 combo.
I noticed in my car that there seems to be a problem with the 61t spur, as it seems to be excentric. That is, mesh can be good in one position, but when the spur is rotated the mesh changes. In that case, mesh can change from Ok to too loose, or too tight.
This is a point for Serpent has to look at.
I'm still using the 61T spur. I'll report back if anything happens.
InitialD is offline
Old 05-19-2004, 06:22 PM
  #10820
InitialD's Avatar
Default Re: Re: Thanks !
Originally posted by Sow&Steady
Profoxcg, good luck with the MTX, when you're stuck on a plateau in terms of peformance get another 710 again ...
Good one !
InitialD is offline
Old 05-19-2004, 06:27 PM
  #10821
InitialD's Avatar
Originally posted by rcpanama
Final question if I install the .10 with the .30 to increase to .4 which one goes first (from top to button) .10 or .30
The thinner copper 0.1 mm shim should go first and then followed by the thicker 0.3 mm aluminum shim. The thicker aluminum shim will protect the thinner copper shim when it goes on top of the piston liner.
InitialD is offline
Old 05-19-2004, 06:28 PM
  #10822
InitialD's Avatar
Default Re: Re: Re: Re: Question
Crashed, D is right. You need to mesh it the gears closer. Don't try to replicate like those of the 705 or other cars ... where people are impressed that you could flick your pinion and the combo of your pinions and spurs rotating forever.
If you're trying to produce this kind of "loose and rotating " meshing for the 61/16 I think it will not work and you'll strip more gears.
I notice that at the first instance, the gears should be mesh tight. Then when the car is run for a few tanks, the gears "loosened" up. And even though it's smooth and rotates more freely, it will not strip. That's what I notice on mine.
InitialD is offline
Old 05-19-2004, 06:29 PM
  #10823
InitialD's Avatar
Ummm, I don't know if jhigga15 refers to radio as in WITH the servos or not. I think the radios from RCMushroom does not come with servos...
If I had a limited budget, I would invest in good servos and a normal Tx/Rx.
InitialD is offline
Old 05-19-2004, 06:38 PM
  #10824
rwisejr's Avatar
3PK dude and welcome to snake land . I remember someone saying that the JR reciever was too big for the receiver box.
rwisejr is offline
Old 05-19-2004, 07:26 PM
  #10825
rcpanama's Avatar
Thumbs up
Thanks you has been a excellent help
rcpanama is offline
Old 05-19-2004, 07:29 PM
  #10826
Thumbs up
now you guys are being mean to me !!!
Profoxcg is offline
Old 05-19-2004, 07:32 PM
  #10827
InitialD's Avatar
Profoxcg, no worries ! If you need any help with your MTX-3, you know you could ask here !
InitialD is offline
Old 05-19-2004, 08:03 PM
  #10828
stormperson's Avatar
Hi,
I just started to build my 710 and due having the first step have the wrong part (two left side lower bulkheads, no right side, lol) I started on other parts and build the shocks and radio tray. Which leads me to ask...
what were they thinking but the rx and servo's right in the path of fuel overflow? Has anyone has issues with this? Its kinda hard to protect the rx or put it in a bag since there isnt much room and the wires wouldnt quite fit... Anyone have insight into this?
stormperson is offline
Old 05-19-2004, 08:04 PM
  #10829
Trader Rating: 2 (75%+)
Default Re: Question
Originally posted by PUNISHER
Has anyone have problems on striping spur gears??
I'm running 16/61 1st gear combo and going through about one spur a week! I'm making sure it has the proper mesh and making sure my motor mounts are secure but still stripping.
Thanks guys for all of the replys on this topic!
I'm going to try Master D's methods on the mesh of the spur and pinion..........a tight mesh. Also I may try Pyramid black book mod.
PUNISHER is offline
Old 05-19-2004, 08:33 PM
  #10830
crashed_1's Avatar
I still have that little bit of NTC3 in me...
crashed_1 is offline
