Serpent 710
#7831
Re: Re: Re: engine shims
Originally posted by Voodo_Magic
yea i thought so too but i run my finger over it to check and nothing moved! But now i think about it are they copper looking?
#7832
Re: Re: Re: Re: engine shims
Originally posted by AMGRacer
There should always be a silver one and it should always be in contact with the sleeve.
#7833
Re: Re: Re: Re: Re: engine shims
Originally posted by InitialD
Yup, the thicker silver one should always be the one in contact with the piston sleeve as the copper ones (if you add them or are there by default) are thinner and can easily be subjected to damage.
Are you going FEMCA ?
#7834
Re: Re: Re: Re: Re: Re: engine shims
No idea. No leave left !
Are you going? How many SG guys are going?
#7835
Re: Re: Re: Re: Re: Re: Re: engine shims
#7836
Re: Re: Re: Re: Re: Re: Re: Re: engine shims
Originally posted by markp27
Hey, you can have some of mine - still got to take 30 days + 10 days flexi-time
#7837
Re: Re: Volvo
I believe Sweedish (pretty obvious) Serpent driver Per-Ola Hard drives with the Volvo body. Hopefully Julius can comment. I know he mentioned that he uses the Volvo wing on the Stratus 2.1 shell.
#7838
Re: Re: Re: Volvo
Originally posted by Julius
I used the Volvo wing on the Stratus 1. It gives a little more steering in high speed corners. The Volvo is a good shell for small tracks. It is good in tight corners. It's a little edgy in very high speed sweepers like the corner onto the straight at heemstede (80kp/h 2nd gear full throttle)
What bodies do you guys run on a high speed, high grip track?
#7839
Re: Re: Re: Re: Volvo
Originally posted by PSI Racing
Thanks Julius.
Thanks Julius.
It's very close to the Protoform Str2 and as such is very smooth and predictable.
Bodies and setup go hand in hand. I talked to Michael Salven yesterday about the race he and Rene had in germany. He had a setup with the Stratus 1 and switched to the Frewer body and had to change the rear roll center to get it to work at it's best.
That makes comparing bodies a difficult task....
#7840
Re: Re: Re: Re: Re: Volvo
#7841
Re: Re: Re: Re: Re: Re: Volvo
Any idea what he did to the rear roll center? I would think the Stratus 2.1 gives more rear downforce than the Stratus 1 but I may be wrong...
#7842
Julius,
Could you give us an update on the status of the changes being made to the 710?
We know the shock towers are already available.
What other parts are being changed and when could we expect them on the market?
#7843
Julius,
Julius,
- Rear tower
- Rear arm (longer hole for the pivot ball)
- Top bumper plate (new material and thicker design)
- Lower bumper plate (new material)
I don't know the market dates, as they depent on distributers stock etc.
#7844
Re: Re: Re: Re: Re: Re: Re: Volvo
The str2 gives more grip all round but also a lot more steering. He changed the top point from InnerBottom to InnerTop.
#7845
Re: Re: Re: Re: Re: Re: Re: Re: Volvo
You mean from UBI / LB to UTI / LB? That would make for lower rear roll center (more rear grip) than the stock?
