Serpent 710
Old 03-10-2004, 07:21 PM
  #5671
InitialD's Avatar
Originally posted by SupermaxxRich
Anybody know where I can get titanium screws for my 710 either in kit or individually? Also anybody know what size screws and how many to get for the 710? Thanks.
There are not available in a pack form as far as I know. You need to get them individually. Some come in a pack of 8 screws or less. Just go to the manual and count the number of screws and their respective size is mentioned there.
You could source from Tamiya or from Speedmind.
InitialD is offline
Old 03-10-2004, 07:50 PM
  #5672
crashed_1's Avatar
Default Disc
Yoh D, who sells the #801345 Vented Disc in KUL huh?
crashed_1 is offline
Old 03-10-2004, 08:28 PM
  #5673
InitialD's Avatar
Default Re: Disc
Don't know but you can try to get the 3 Racing one which is for Kyosho V1R. The design and pattern is exactly the same as the 801345 vented disc.
If you want, I could (with my charitable heart ) donate the 3 Racing disc to you as I have it lying around. You need to polish it up though because it is discoloured due to it being overheated !
Can't you get the new disc? The new disc (9606) is having a 33 mm diameter while the old one (801345) is at 32.7 mm for what it's worth... A little more surface area. I believe the 3 Racing one is the smallest of the lot. Only very slightly smaller in diameter than the 801345 disc.
InitialD is offline
Old 03-10-2004, 08:36 PM
  #5674
Registered User
Pyramid's Avatar
I think a good idea for the faq page would be to have section where you could list all of the hop ups that have come out or will come out with there part #'s next to a description of the part. That way everybody will know when something comes out. Just a thought.
We did that before.. but then got complain since, fortunately on one of them, it has the newest next kit release that makes others having a hard time selling the old one
Speedmind did have the Ti screw set for Veteq but not S710.. I guess not much market for it.
D.. yes, messy at building.. then just have more time at play.. I`m kind of like the idea.
Pyramid is offline
Old 03-10-2004, 08:42 PM
  #5675
Registered User
Pyramid's Avatar
Default Re: Re: Disc
I think they are meant for 1/8 scale? as it comes in pair and quite expensive (S705 pricing era)
Pyramid is offline
Old 03-10-2004, 08:52 PM
  #5676
kitracer's Avatar
nice option parts from Kai
kitracer is offline
Old 03-10-2004, 09:05 PM
  #5677
Registered User
Pyramid's Avatar
Dammmmm NICE... where can I get those in HK?
Pyramid is offline
Old 03-10-2004, 09:37 PM
  #5678
InitialD's Avatar
Default Re: Re: Re: Disc
Yes it is expensive. But I believe it's harder than the 801345 vented disc. Since it comes in a pair, you can share it with someone else. The team drivers use this brake disc with the race brake pads 9607 if I'm not mistaken.
InitialD is offline
  #5679
markp27's Avatar
Not that long lah !
I'm a purist. I only go with sedan shells unless somebody sprays them for me ! <hint, hint>
Didn't you always run your 705 with a Lola shell? Do you still run the 705?
markp27 is offline
Old 03-10-2004, 09:40 PM
  #5680
markp27's Avatar
Came home today and there was a snake waiting for me!!! My 710 finally came. Going to go through it all tonight and make sure there are no parts missing. Should be getting my spare 710 next week. Hopefully by the end of this weekend I'll have most of the car together. Still need a pipe. I'm thinking of going with the new Turbo II Outlaw pipe from RD Logic. SOOOOOO EXCITED!!!!!
COOOOOL Your're going to enjoy building tjhis car
markp27 is offline
  #5681
InitialD's Avatar
Nice on the laydown throttle / brake servo. But I don't quite like the receiver placement. It's simple but then exposed to fuel !
InitialD is offline
Old 03-10-2004, 09:41 PM
  #5682
markp27's Avatar
WOW! that's clean!!!!
markp27 is offline
  #5683
rodrigo1508's Avatar
I am going to pick up my new 710 next monday so I wanted to know if a JR RS300 FM Synthesized Reciever would fit
rodrigo1508 is offline
Old 03-10-2004, 09:42 PM
  #5684
markp27's Avatar
Maybe a good friend of ours, who already has Ti screws, has already counted them?
markp27 is offline
Old 03-10-2004, 09:48 PM
  #5685
InitialD's Avatar
Since I built the 710, the 705 was orphaned. It was made worse when I had to cannibalised my 705 in Thailand for the servo and receiver because I had some problems.
Just got a cheap servo for the throttle. I'm putting it back slowly and planning to run the 705 this weekend just to kick those with a 710 ! Oh yes, it is slightly modded with Centax 3 and the gearbox from the 710 fitted on.
I'll run the 705 with a salon shell.
InitialD is offline
