Serpent 710
#2371
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
None of the various special tools cluttering up my tool box will hold the clutch bell while tightening the pinion gears. In the past I've torqued them on tight with lock tight, so they wouldn't loosen with deceleration (other cars). So I wound up holding the bell in my hand and using the plastic gear holders to tighten them, and hope the engine will finish the job.
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
Just a little something from the maker of the ROAR nat'l champion!!
#2372
Originally posted by Zizu
There has been no postponement yet so I assume it's confirmed.Suppose to be on 12-14th March 2004.Will you be there?
#2373
#2374
Originally posted by InitialD
Just curious... The grooves look like it will hold the pinions. The pinions on the 710 and on some cars are 0.8 pitch. Do they universally cater for this? I know the R40 uses normal 1.0 pitch gearing.
speaking of which,wait till you see what HPI has in store for gearing for the r40..
#2375
actually it looks like there are two sets of grooves for different pitches.
Am ordering now!
#2376
You can check under Racing Area from this link
http://www.teammagic.com.tw/phpBB2/index.php
#2377
Cool. I guess you already got your 710 assembled? If you have a machine shop, the holes in the one way driveshaft adaptors can be done.
#2380
You didn't tell me that you're getting a S710!
what kind of engine r u intending to put into it?
#2381
Guys
I have a question, when your putting together you 2 speed and you place it on the two speed shaft is there supposed to be a lot of play between the second gear and the bearing to the left of it. I put that round spacer inbetween and its still about 1.5mm to 2mm movment between the two, that dosnt seem right, what could be wrong?
#2382
Originally posted by rcjayy
Guys
Guys
there's a shimthat goes on first-not labeled. Also check the figs in the Reference guide when things are not clear-gives additional info
#2383
Originally posted by jfc_tech
Hi everyone? Im a baby snsake here...
could any1 tell me is the bearing mentioned in the step 2.3 U7 7x14mm sealed or not. The picture shows its a sealed(purple) bearing, but what i found is not(or did it accidentally opened!!??)
thanks.
thanks.
#2384
thanks.
thanks.
#2385
Guys
Guys
The 2 speed shaft must have end float or else you can damage the shaft bearings, this happened on the 705 if the shaft was not setup correctly.
