Serpent 710
Originally posted by Pyramid
you wont believe how Suruth able to pass that chicane on his every laps.. great performance
Originally posted by InitialD
Different from the earlier pic posted.
Take out that oxygen mass and put on the binoculars and you should be able to see it clearly.
he had traction roll problem. change to solid and 2mm caster clip in front
Prophet hard at work
I went with harder front tires. But later on I found out that it could be the tire diameter that I was using was not correct and probably made for the slower corner entry / exit. Changed it back to 37 front and rear with 59 mm rear and 58 mm front tires during the main and it was on rails.
Originally posted by Sow&Steady
Brader ...
Please go to 3Hobby and look at the top right in the calendar. I need to go now but will look at the tracks nearby and see which is best.
Maybe you and Mark can come along at the same time?!
Brader ...
As far as I know, everybody had traction roll problem. Even in the B main, kitracer traction rolled twice.
Re: Prophet hard at work
Oh hail great Prophet
Re: Re: Prophet hard at work
Originally posted by crashed_1
Great pics! I am soooooo jelous i hope it comes to aussie!
I like it D, very clean and tidy but a bit disappointed to not wearing the snake cap
See Uncle Crash, even Pyramid said my pit table is neat.
Re: Re: Re: Prophet hard at work
Just stick a picture of the Prophet on your toolbox and all will be fine...
