Serpent 710
from us here, i think 2-3 guys...or maybe 4...a few Mugen guys buying 710...and testing them now on track. My Friends from HMS Racing should be there.
Re: Re: Gettin Jiggy with Rear Anti Roll Bar
Originally posted by InitialD
For the new sway bar, I'm currently using the 2.5 mm with the plastic holders meant for the 3 mm. That should ensure that the sway bar movement is free.
.....a few Mugen guys buying 710.....
Re: Re: Re: Gettin Jiggy with Rear Anti Roll Bar
Originally posted by Sow&Steady
Wouldn't that make the bar itself go up and down rather than rotate around its own axis within the holder?
FJC, you convinced them to do this?
yep...u can say that...i manage to influence them..but its actually Gary doin all the work....i just 'fan' them on track with my reliable Nova Max
i think im the only one left with all original 710 parts...well, ok...the bumper i change(after high speed stoppage by the bricks ..thats all.
its actually 4 guys...One got fed up with Gary keep winning with his 710 & his MTX3 on 2nd. Another 1...bcoz i force him...im not lending him any tools or starterbox, or even the glow plug in the pit area. i said..u have to change....
yea right...why im promoting this 710 thing...i also don know...at least i got discount from lhs here.
Re: Re: Re: Re: Gettin Jiggy with Rear Anti Roll Bar
It stays perfect as it is. You would not notice that a 3 mm plastic holder was used after install.
i have to race & beat them on track in order for them to witness the power of 710...especially in the hand of me...only once in A-main.
Re: Re: Re: Re: Re: Gettin Jiggy with Rear Anti Roll Bar
Originally posted by JustRace
I'm using the 2.5mm with it's intended plastic piece. It's not binding and is very smooth movement. I haven't tried it with the 3mm plastic but I would think it would cause a little bit of a slop.
Maybe D tightens the screws down enough to prevent slop.
Re: Re: Re: Re: Re: Re: Gettin Jiggy with Rear Anti Roll Bar
can someone post here and pm me (i don't check this forum often) the easy way to take the two speed out??! every time i have to take the side brace of i need to take the entire shaft and two speed out!
also is there a way of taking the motor out without having to loosen the motor mount screws that attach to the motor? (ie the top screws)
also is there a way to adjust the active toe washers? they seem very figetty and the only easy way seems to take the whole back end assembly off?
i bought this car second hand. my old car was a easy peasy mugen (i am currently racing craig1's serpent, the modified 710 which he may of posted pics of in the past)
Re: Re: Re: Re: Re: Re: Re: Gettin Jiggy with Rear Anti Roll Bar
Else, the other way is to take out the 4 x M3 screws that mount the engine crankcase to the engine mounts like what you've mentioned. Easy if you have 2.5 mm ball tip allens (Pyramid !), then it's easier. Then you do not need to take off the engine heatsink to access these 4 x M3 screws to take the engine off.
Anyway, why do you want to play with them? Stick to the neutral position. It should be more than enough. After you've exhausted the rest of the settings, then perhaps you can play with the DRS.
