Serpent 710
#1816
Re: What is Dynamic Rear Steering ?
Originally posted by Profoxcg
does this mean this car truns with all 4 wheels like a skyline?
#1817
Re: Re: Re: Re: What is Dynamic Rear Steering ?
Originally posted by Julius
It is not the easiest trackside adjustment. It's a little tricky changing the position of the spacers.
#1818
Originally posted by InitialD
No, more like what they have on some Citroen cars...
#1819
Originally posted by spawn
I donno whether I am correct but anything less than 30kmh, the rear will turn opposite of the front to assist in parking and tight turns and above 30kmh it will turn in the same direction to assist stability.
Only problem is trying to align the steering probably which requires an expert.
#1820
Are you suggesting the aide of a fuzzy logic device on our small cars?
Yeah, aligning the normal 1/10 scale car is already cumbersome as it is.
#1821
most full size cars use some amount of dynamic toe geometry, current gen Celica for example, although I can't remember which direction.
#1822
Originally posted by lawndoggie
HK is cheaper if you know the people... but I am still new to the hobby.... while everyone gets 20%off.. I get none!!
This is another reason I am not planning on getting another snake. There are 3-4 retailers that carry snakes here, not one of them are very nice to their customers.... thats my observation/experience. Of course many people will not agree with me...
In the end, its not just about having fun playing on the track, I want to enjoy the purchasing process too.... but lets just say that I hate buying from those dickheads...
#1823
710 Screw Count
For any of you who want to replace the 3mm screws with titanium ones, here's a list:
Quantity-Type-Size
2-Cap Screw 3x18mm
1-Cap Screw 3x14mm
2-Cap Screw 3x16mm
14-Cap Screw 3x12mm
12-Cap Screw 3x10mm
26-Cap Screw 3x8mm
8-Cap Screw 3x6mm
2-C.S. Screw 3x10mm
4-C.S. Screw 3x8mm
6-C.S. Screw 3x6mm
2-Grubscrew 4x6mm
3-Grubscrew 4x4mm
8-Grubscrew 3x10mm
5-Grubscrew 3x8mm
9-Grubscrew 3x4mm
10-Grubscrew 3x3mm
Quantity-Type-Size
2-Cap Screw 3x18mm
1-Cap Screw 3x14mm
2-Cap Screw 3x16mm
14-Cap Screw 3x12mm
12-Cap Screw 3x10mm
26-Cap Screw 3x8mm
8-Cap Screw 3x6mm
2-C.S. Screw 3x10mm
4-C.S. Screw 3x8mm
6-C.S. Screw 3x6mm
2-Grubscrew 4x6mm
3-Grubscrew 4x4mm
8-Grubscrew 3x10mm
5-Grubscrew 3x8mm
9-Grubscrew 3x4mm
10-Grubscrew 3x3mm
#1824
Re: 710 Screw Count
Quantity-Type-Size
2-Cap Screw 3x18mm
1-Cap Screw 3x14mm
2-Cap Screw 3x16mm
14-Cap Screw 3x12mm
12-Cap Screw 3x10mm
26-Cap Screw 3x8mm
8-Cap Screw 3x6mm
2-C.S. Screw 3x10mm
4-C.S. Screw 3x8mm
6-C.S. Screw 3x6mm
2-Grubscrew 4x6mm
3-Grubscrew 4x4mm
8-Grubscrew 3x10mm
5-Grubscrew 3x8mm
9-Grubscrew 3x4mm
10-Grubscrew 3x3mm
Quantity-Type-Size
2-Cap Screw 3x18mm
1-Cap Screw 3x14mm
2-Cap Screw 3x16mm
14-Cap Screw 3x12mm
12-Cap Screw 3x10mm
26-Cap Screw 3x8mm
8-Cap Screw 3x6mm
2-C.S. Screw 3x10mm
4-C.S. Screw 3x8mm
6-C.S. Screw 3x6mm
2-Grubscrew 4x6mm
3-Grubscrew 4x4mm
8-Grubscrew 3x10mm
5-Grubscrew 3x8mm
9-Grubscrew 3x4mm
10-Grubscrew 3x3mm
#1825
Re: Re: 710 Screw Count
Originally posted by Paolo M
Do you think that are needed? Alluminum saves ore weigth!!
#1827
Re: Needed in some places.
I like to use titanium as much as possible, like on steering and shock ball inks, shock tower mounts, etc. I usually use alum on the servos. Here's my new MTX 3.
#1828
Originally posted by utopian
Where did you buy the 705? Back to the shop and ask for the 20% discount. I get 20% discount from LHS for Serpent parts.
#1829
Re: Re: Re: 710 Screw Count
My opinions, use stock screw 1st.
I have no digital balance, but I am sure its way lighter than stock 705. 50gr is minimum.
I found that if I built step 6.7, the 23mm threaded rod just in manual 44.5mm. I cannot align the servo saver with the (90 deg.) servo horn position.
If I keep this setting and adjust the horn to reach servo saver center position, the left turning is cannot reach its max. travel evenwith 30 point difference in EPA.
But luckily I can remove and replace that rod without lifting the upperdeck. I ended up with 40-41mm. And now the horn is 90 deg., the saver was center(in Hudy setup) and the EPA diff is only 4point. You need to replace the ball end.
Im using ftb low profile servo S9550.
Any comment on this?
#1830
Re: Re: Re: Re: 710 Screw Count
The Serpent manual usually likes to refer to the Sanwa/ Airtronics servos as example. I bet they fit just like the measurement in the manual if you were to use a Sanwa servo.
