Serpent 710
Old 09-06-2004, 05:41 PM
  #15181
kidDynomite's Avatar
Originally posted by rcpanama
I just finish building my second car (710)
rcpanama, where did you get those buttons over the engine heads? BTW, those are some hot twins I'd like to meet. Stay fast!!!
kidDynomite is offline
Old 09-06-2004, 05:49 PM
  #15182
rcpanama's Avatar
Does are Mugen Head Protector you can get them in RC-Mushroom
I will do my best
rcpanama is offline
Old 09-06-2004, 06:07 PM
  #15183
ok now i installed my engient he cluthc when its on the engine and not in the car spins freely both ways but when i put the engine it it will go forwards but i cant push it abcks wards is that right?
Bxclip is offline
Old 09-06-2004, 06:13 PM
  #15184
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
You can get them at Horizon Hobbies...
http://www.horizonhobby.com/Search/D...&OverallCatID=
fastharry™ is offline
Old 09-06-2004, 06:43 PM
  #15185
Suspended
Default Re: Re: Re: 710 at the US Nationals
Originally posted by tomkelley
I didn't say anything of a video. I have pics in my camera, I still haven't unpacked my stuff yet.
any pics?
SERPENTFREAK69 is offline
Old 09-06-2004, 07:06 PM
  #15186
InitialD's Avatar
Default Re: 710 at the US Nationals
I have pics of their cars prepped for the main with the new megas. The cars performed very well all weekend and the new mega 12's had plenty of power, enough to pull others on the strait.
Thanks for the pics tomkelly. Do you have their respective setups? It would be interesting to know since both running oneway and solid front respectively on a same track irrespective that their driving styles differ.
Anyway, I suspect both are running solid front looking the amount of caster clip settings.
InitialD is offline
Old 09-06-2004, 08:23 PM
  #15187
InitialD's Avatar
Originally posted by fastharry
Armand Van Tal , the second engineer at Serpent has left of the side the development of the 1/10 720 Touring to work 24 hrs. per day with the new design of the 995-R. -- We want to be the Number 1 , gain ''.
With all due respect to the Dutch people, that is one thing I know that they would not do... Work 24 hours a day ! Sorry but I can't help but laugh at this. Take all this with a pinch of salt.
InitialD is offline
Old 09-06-2004, 08:25 PM
  #15188
InitialD's Avatar
Default Re: Re: Re: Re: Re: 710 at the US Nationals
Brian Berry's 710. First time racing the 710! THats my locking one way parts in his car.
The front shocktower spaced in front a little, custom made transponder holder, throttle servo on the underside, new rear sway bar and no side belt !
InitialD is offline
Old 09-06-2004, 08:27 PM
  #15189
InitialD's Avatar
Default Re: Brandon's car.
This is Brandon's car, I beleive he was using the one way.
Front tires cut narrower than 26 mm (I guess the same as what he did previously but then using solid front), new rear sway bar, possibbly hudy steering rods??, hudy front dogbones, throttle servo on the underside, lightened pulley adaptors in the front, Hudy mid shaft (probably modified the hollow one from the 705), titanium screws and front aluminum sway bar holder. I have a sneaky suspicion that the wheelbase could be altered too.
InitialD is offline
Old 09-06-2004, 08:28 PM
  #15190
InitialD's Avatar
I ran the HPI stratus, but I had some difficulty getting it to pass tech when I tried to wedge the body.
I see you have a long tubing with the external filter? Is that going into the carb or coming from the pipe?
InitialD is offline
Old 09-06-2004, 08:29 PM
  #15191
InitialD's Avatar
I will be running this Sunday so we will see how it will go, my 710 is doing very good so I hope I can get a good result.
rcpanama, nice pair of snakes. A male and female? Hope you get more snakes.
A tip ! Don't tell other people too much about the 710. Else, everybody starts to get better than you and you loose your position. (j/k)
InitialD is offline
Old 09-06-2004, 08:30 PM
  #15192
InitialD's Avatar
Originally posted by Motorman
the other reason is there is a minimum tire diameter rule and a minimum tire width rule. Trimming the tire to minimum diameter on the inside allows you to still be legal and run a narrower front tire.
Hey Dennis, how was your run and your team mate's run?
InitialD is offline
Old 09-06-2004, 08:34 PM
  #15193
tomkelley's Avatar
setup from qualifying to final was a bit different. I think to adjust for tire wear mainly for the 1 hour finals.
Standard Roll Centers front and rear. Standard DRS position. 3.5 mm ride height. 42 shore tires superglued cut down to 57-58mm for qual. 3mm or 2.5mm rear roll bar set pretty stiff. Red Springs. shock and dampening I'll have to guess here, but most likely 40-45 weight oil.
Everything else would be guessing or speculating so I'd rather wait till Art Carbonell or brian berry publishes their nats setups. Yeah I sat right next to the snake team but I wasn't really involved in their setup discussions too much. What they were saying that the front solid on this track made the car feel more safer and comfortable for him to drive. Really though I don't think they were overcompensating for the front solid axle other than the rear differential and sway bar settings.
I do have to admit that the new Mega .12 engines performed quite admirably. I just couldn't figure out why they had set their bottom end setting on the engines so lean, but they sertainly pulled a lot of cars on the long strait and sweeper.
tomkelley is offline
Old 09-06-2004, 08:50 PM
  #15194
tomkelley's Avatar
Filter is on the pipe pressure line.
Old 09-06-2004, 08:52 PM
  #15195
tomkelley's Avatar
Default Re: Re: 710 at the US Nationals
Brandon was front one way most the time, not sure if he went to the locked for the main, my guess is not because he was using one way in qualifing.
