Old 10-19-2003, 06:52 AM   #1
Canuck's Avatar
Trader Rating: 25 (100%+)
O.S. .12 CV to CV-X conversion ?
I bought an OS recoil pull start assembly to convert my OS .12 CV to a CV-X.
Now before I plung in ripping it apart, I'm wondering what else do I need ?
Does the crankshaft need to be replaced ?
Thank's
Canuck is offline   Reply With Quote
Old 10-19-2003, 06:55 AM   #2
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
you need a diffrent crank,and the piece that connects the crank to the pullstart.....
its listed in the instructions..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 10-19-2003, 10:24 AM   #3
Canuck's Avatar
Thank's, I just noticed that the crank for the pull start version is different and has and extra stub extruding from it to hook up to the pull start assembly.
Old 10-19-2003, 05:36 PM   #4
treky11's Avatar
canuck - i have .15 cv x hyper that i was going to put on ebay if you are interested. it was only run for 6 tanks. no scratches.
treky11 is offline   Reply With Quote
Old 10-19-2003, 08:25 PM   #5
popsracer's Avatar
Default O.S. .12 CV to CV-X conversion ?
Canuck;
Converting a NON-pullstart to a Pullstart Engine requires at least 4 Major parts added.
1) The Pullstart mechanisim. ($20-$30 usd)
2) A New Pullstart backplate for the Engine. ($10+)
3) The Crankshaft has a special extention on the crankpin to engage the coupling shaft. ($35-50+)
4) Coupling shaft. This has a notch to engage the crankpin and goes through the backplate bushing to the pullstarter mech. ($???)
5) One-way Bearing for the starter, as most do not come with one if purchaced seperately. ($8-$15)
You could probably have bought a complete Starter Box, for the coast of adding a pullstarter.
popsracer is offline   Reply With Quote
Old 10-19-2003, 09:05 PM   #6
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
you will need a--- one way bearing, and peice that goes on crank for the one way bearing to fit on and you will need another crank that has the little peg on it for the crank peice to fit to...you will need another backplate also...and then of course the pullstart assy... ..oh and 4 screws for the pullstart assy..that should do it
2mcgrath is offline   Reply With Quote
Old 10-19-2003, 09:10 PM   #7
Omar's Avatar
why do u want to convert your non pullstart engine into a pullstart. i rather a non pulstart anyday
Omar is offline   Reply With Quote
Old 10-20-2003, 05:43 AM   #8
Canuck's Avatar
Thank's for the info guys ! Ya, I know I should get me a starter box and I will eventually. I just have all these parts kicking around doing nothing and I want to put a pull start together.
Nice to hear from you Popsracer ! Always appreciate your advice...
I do have the following parts already:
1) The Pullstart mechanism.
4) Coupling shaft.
The only thing missing is the crankshaft with the special extention on the crankpin to engage the coupling shaft.
I understand that this is not the same crankshaft as a CV-RX. I need to find me the following crankshaft part number:
21202000
So if anyone has a spare in new or excellent condition , let me know !
Does anyone use any special type of sealant on the backplate ?
Old 11-03-2003, 11:01 PM   #9
no just use the supplied gasket for the backplate no sealant
Old 11-04-2003, 03:53 AM   #10
Canuck's Avatar
Wil just use the gasket. Thank'S
Still looking for a crank !
Old 11-04-2003, 08:00 AM   #11
Old Skool's Avatar
Don't forget...you'll also need pullstart engine mounts and a pullstart flywheel. Both are slightly larger then the non p/s variants.
Old Skool is offline   Reply With Quote
Old 11-04-2003, 08:12 AM   #12
Canuck's Avatar
Shoot ... different mounts, this is getting too $$$$
I think I will buy a starter box LOL
Old 11-04-2003, 01:45 PM   #13
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
Yeah and it would be a whole lot easier to boot!!!
Flash Gordan is offline   Reply With Quote
B44 conversion to T44 Craps Electric Off-Road 31 04-22-2011 06:06 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
CONVERSION 32819toon Nitro On-Road 6 05-02-2006 01:07 AM
WTB a LCG conversion kit MoFO R/C Items: Wanted to Buy 0 09-24-2005 07:40 PM
