Engine Wars Thread
#572
Re: MT 12 OR MR 12
Originally posted by rcmike
Which would be better for a small track like at your LHS?? THANKS I cant find where mugen said the characteristics of each""
But it is pesonal preference for racer.
#573
I'd suggest the MR12. I've seen several racers with them and they have all ran well. I raced my NS12S3 at the HobbyTown track here in Austin against a MR12 and it was almost as fast. The difference increases on a bigger track like the SWCS, but for a smaller track, it's not that different.
#574
Originally posted by Top Gun 777
I got first results from testing. It is so exited and so unbelivble, don't realy want to give details. Just can tell you, tryed AAC, ABC and Berilium. Run in time 2 minuts on bench at idle, 3 laps with 50% throtle and then full throtle ( all set ups-AAC, ABC and berilium the same). Mugen fuel, 20% nitro ( can't find lower nitro fuel at all).
7-8 tanks per set, stays easy aganst any 5 port outlaw ( actualy passing all of them on any part of track), temperature ( I don't mesure at all) but somebody came and mesure it, was 205-217 F, run time-this is most unbelivble I have never see-between 7min 35 second to 8 min 08 second. Timed four times. Still don't belive it and didn't analize it yet, will do it tonight. Didn't change tunning between swapping the Piston sleeve sets, just swap the sets and no needle was touched at all. My next step is to check how long it will last at this performance.
Dino, saw your "Dragon" 5 port. Very impressive engine. I just noticed the guys Had hard time to tune it, but performance was good.
#575
hey guys what do you think about the new Fantom '03 FR series engines??? just need a feedback about these engines...I've been wanting to get one...are they worth it?...they're a lot cheaper than most of the engines i saw...i'm going to use it on a NTC3
#576
could someone post some pics of some con-rods that have been modded and go over the basics of how to and an whats there reasnoning behind what they did.curious bout opening the venturi on a carb. ,does it need to be tapered or can it be widened the same diameter all the way down?
#579
Re: the new dragon engines by sts
Originally posted by tallyrc
are the new dragon engines by sts roar legal and are they supposed to be more powerful than the sts rs3's? how much are they?
For half the price.
#580
they are suppose to be on the same level as NS12 and NOVAMAX engines.
#581
Originally posted by FAST1
Yeah, but do they have the same level of quality as a Italy Novarossi motor??
I am comparing them to O.S
I am not sure about the STS, but I would not be surprised if the quality is better than that of novarossi.
#582
OK, finally I've learned some new stuff here. OS quality is higher than Novarossi and STS quality is higher than Novarossi. So why there are many people buy the high price and low quality stuff.
#583
the performance of novarossi engines is top notch, thats why.
I am not saying that they are bad at all. In fact, I run a novarossi based engine myself.
I am just saying that other brands, such as STS, though not as popular, still deserve a chance, for they too, are powerful engines.
#584
Novarossi
Hey guys. I can't find on Novarossi web site any more statment which is prohibiting modding of Novarossi products. They remove it or I just can't find it?
thanx for advance for right direction.
#585
Engine keep dying on idle
I have a Novarossi T5 S1 5 port engine and just broken in.
The problem i have is i have to replace new glow plug every few tanks and i have tried all High/Low/idle needle setting but the engine still died on idle (But the engine has a lot of power and running very good. about 210 - 230 degree once i am able to run it)Whenever i let it idle more than 2 seconds. It will die right away. I found out that if i let the Glow igniter on the glow plug, it will not die at idle. But it is a new glow plug and i have been doing that for last 3 praticeS. Someone told me that i may need to try to add a 0.1 mm shim under turbo head? Anyone knows why is doing that and what is the problem.
