Kyosho FW-05R
#4726
Parts
Hi guys,
I've been running my fw-05r for approx 5 months now. Have chimed in a couple of times but mainly been following the thread. I logged into Kyoshoamerica the other day and didn't see the FW-05RR available nor parts. Do you guys also have trouble finding parts locally? Will this change, and will I have to convert to RR version, doesn't seem to be many R parts around any more.
I have a question about the RR rear, is the shock mount config diff, the reason why I ask is I tried to mount the 3R RR rear shock tower and it doesn't seem to fit. What do I need to convert?
On another note, I have Ofna 120 wght diff oil in the front diff, makes it tough to turn(diff action, not car turning) and the car really handles well w/ this set-up, even on tight technical tracks.
Thanks,
Havy
Thanks,
Havy
#4727
Originally Posted by impalabob64
bobby here ,man lock that frt diff up,with some shoo goo,or serpent cleaning clay.trust me it works perfect.my buddy has 2 rrr ,running solid in frt an i can power steer in to a corner full throttle.
#4728
Originally Posted by havy
Hi guys
Thanks,
Havy
Thanks,
Havy
#4729
Thanks,
I'll take another look at it.
havy
havy
#4730
kyosho parts
havy, if you have the part #'s call kyosho america and talk to customer service. they have parts for the fw05r and rr. i just got parts from them 2 weeks ago. use the toll free #. have any of you guys tried the evolva springs? i have them on my car and its perfect. the light blue springs. 30 wt front and 50wt rear with the 1.2 pistons.
#4732
wow bobby 30k rear diff and you still have traction on this car?
#4733
didn't you hear marcos - bobby's car is dialed in
so softer frt (softer spring, shock oil, and slanted shock angle, coupled with A ackerman) - gives better on power steering?
#4734
bobby is probably using 35 or 37 shore tires
#4735
RR convertion kit
guys, any store that you could recommend that still sells the FW-05RR Convertion Kit already contacted RC Champ but they say it is already out of stock and there will be none already since it is a limited item only
#4736
#4738
Originally Posted by jeffreylin
Yeah it's long gone as far as I know....
#4740
hey Bundyman
Marcos is right ,i checkout the traction, then i decide what i think would work. i really dont like 35 but, if traction is not to the car,s liking 35 on the rear only.Right now i love running the jaco nitroshoes 38shore frt an rear 59 frt 60rear. 39t ringgears i save my 37,ringgears for the bigtracks.i run my tires alittle taller in rear the is for when power through a swiper.
