Kyosho FW-05R
#361
Originally posted by mugenracer
I ran the car today for the first time and i was impressed. the car is as free as a NTC3. has fast corner speed and holds a thight line. Took a while to adjust the 2ng gear. car had way to much stearing at first then changed to 42 front and 40 rear (foams) and it was diled. was a little under geared for large track but not bad with stock gearing. there was onther car faster on the back stright but on the infild this car was fast. Still workign on set up. going to change the back dif oil to 50,000 or 75,000. well back to the track tommarrow for some more testing. Robert
#362
Jeff i ran at Rev. with the stock foam tires it had way to much stearing. was a little hard to control. so i went to 42 front and 40 rear. still lots of tracking but much better. also i dont know when but they did spray the track with VHT not long ago. I am running a old MT12 I had laying around. But i want to buy a new engine. Just dont know what one to buy.
#364
Originally posted by Joehwee
You can only adjust the rear roll centre of the 05, the front roll centre are not adjustable.
#365
Ran the car today and it was hooked up! The combo of the Alfa body and the 37's all around made the car so much better. Definitely quicker than the Mugen in the infield. Got it to handle like the Evolution but this corners way flater. Some little adjustments and this car will be perfect.
#366
yeah i am also running the losi Alfa body. Jeff you said you got the 39 ring gear. will that give you more top end? I didnt see that in the manuel. whats the part No. Also just would like to check where everyones buying there spare parts or hop ups not that any are needed. but i need to gear it up.
#367
Oh yeah I did run the 39tooth ring gears today. It was a better on the straight. My motor is going though. I still have to break in my MT-12. I should have no problems getting this car to run in the low 17's and high 16 second laptimes.
#368
How do you have your front set up? If you built according to the kit you will have about 2 degree toe out in front. That seems a little too much...
#369
I am running 1.5 degrees of toe out. I think that part of the manual is wrong. This car needs toe-out for on power steering.
#370
Thanks for the link. I am running 1 deg toe out in the front and 2.5 toe in In the back. its should be ok to run 2 deg out in the front.Im still playing with the set up but it feels good the way it is.
#371
I have been looking everywhere for the 39 tooth diff gears. Thanks for the post. Are you running a 27 tooth second gear w/ the 39's. If so how was your car on the straight? Just got the 27 haven't tried it wondering if I should wait for the 39'S. Also have a 1 way that I haven't tried yet. Much testing to do, but the car kicked ass before our series was shut down for winter.
#372
The 27tooth pinion is what I have been looking for along with the 45t 2nd gear spur. I got the ring gears from Hong Kong. With the 39t ring gears I don't get nearly as embarrased down the straight. Everyone is running modified and 30%. Whatever I gain through the infield I lose on the backstraight. I'll give them something when I get a new engine. My NS is DEAD.
#374
Are you by chance running at revelation in Ontario, Ca.? Thats where I first experienced our cars undergearing. It sounds like you have the right answer, will order my 39's.
#375
Originally posted by JordanC
Love the Car... There's way too much toe out according to the origional setup sheet. I have only put it on the track 5 odd times, but found .5 deg toe out on the front, 1 deg on the back is nice. I also think it needs harder rear diff oil, looking at going to 50k.
