HPI R40 Nitro Car Forum
#9812
Originally Posted by Minus
Hello everybody,
For race under rain, i want buy pit shimizu tires.
Could you give me the right reference i must take and reference for the insert i must use with it.
Many thanks.
Many thanks.
But most likely you will want soft tire. The harder the insert , the less grip , more response and less wear. Softer insert , more grip , more wear , less response.
I would go with a softer insert and softer tire. May wear fast , but the r40 needs grippy tires or its like trying to drive on oil.
#9813
Ok thanks
So a softer tires like D20 pit shimizu and a medium insert can be a good choice in wet tracks.
#9814
Ok thanks
I know a few of us have tried rubber tire on the r40. All I got was massive wheelspin.
#9815
Thank you
#9816
Originally Posted by Artificial-I
Thats probably a good start. All I know is the r40 says basically for use with foam tires and on blown paved race tracks. I think this is right on the box.
#9817
Oneway and throttle brake servo
My R40 has the oneway diff in the front. So that means no braking in front. Do I still need a strong servo for throttle/brake, or could I use a more generic servo. maybe something like the futaba 3003.
What should the ratings of this servo be when a oneway is used in front?
#9818
Throttle servo "strength" has never really mattered to me on most my nitro vehicles. If anything its "speed" you want so you get quick throttle response and quick brake response. If anything strength is going to harm the carb linkage or put more wear on the brake disc and like components.
I have used the s3003 mostly or any cheap laying around servo for throttle. If I find some cheap faster servos that work well and have low torque I also use those. Right now even the s3003 isnt rated as the fastest , it does beat out a few other servos in response and speed even if they are rated faster than the 3003.
The other good thing about s3003 on throttle , is less drain on the battery , easier to pull close with a TRS (throttle return spring). I really cant find a much better throttle servo if you ask me. Especially when its only $10 dollars.
Otherwise I have tried them all. The stronger the servo , the harder it seems to close via TRS to where its almost impossible, in which your putting so much tension on the spring anyways your making the throttle servo work hard to fight that tension. Especially a metal gear servo , the plastic gear seems easier to move about without power.
The other thing is with one-way you really cant use the brakes at all. I know when I race I dont use it at all with the one-way. I never touch them. Just a waste of time to me and gets you thrown off balance trying to get back on the throttle correctly after playing with a car with a one-way on brakes.
All you need is a good TX that can vary the travel on the brake and dial it in to where you can brake and not spin out. Which you will find is almost non-exsistant braking. Otherwise I think throttle servo strength is a weakness on most on-roads and makes the car more touchy with the brakes and all the factors above. Save money , weight and power and go 3003 on the throttle all the way. Unless your used to having fast servos you wont really notice. Its best for throttle response...everything else strong/exspensive servos are overkill on throttle. Ill admit ive run digital fast servos on throttle. It feels nice and crisp and responsive...but what car really needs super fast throttle response. When grip needs to be maintained , smoother slower is better. But this comes down to individual prefrence. Ill just say personally , im all for the s3003 on throttle.
#9819
Originally Posted by Rapid Roy
I used sorex 36r's at my last parking lot race because the track was so damp in the 1st heat. I used the same setup as foam, or maybe 1/2 degree less camber, can't remember for sure. It was pretty slippery, but much better then the foams on damp pavement. I have run rubber at low grip/dusty surfaces too and they hook up a little better then foams. So there are times when rubber works. I always try the foams 1st though.
I probably should have used some grip compounds , cause the tires were a bit dry. On my racer2 , same exact tires work great. So , I just figured it was a setup of the R40 causing this and to warrant the suggestion right on the r40 box.
#9820
The stock R40 brake is for some bizarre reason a stamped piece of metal. Now there is no way a stamped piece of metal will be flat, and none of my brake discs have ever been. You ever had a real car with a warped brake disc? The shudder like all get out and your braking suffers. Same with a rc car. If your brake disc causes your braking mechanism to "shudder" then it is because it is going through a series of higher and lower braking forces as the disc rotates. Now remember that highest braking is achieved when you are just before lockup. If you are pulsing through the braking system you may only be able to achieve maximum braking force for 20% of the disc rotation, the remainder of the 80% is less force because of the uneven braking surface meaning you slow down more slowly.
The same thing happens when you use a weak braking servo. You cannot see it easily, but trust me a stock servo pulses badly under higher braking loads because they do not have sufficient holding torque. This happens even with a perfectly flat brake disc. Again see above why this is bad.
The optimum setup for high braking power with a oneway is a servo with a good holding torque (coreless digitals) a flat disc brake (the HPI optional one works very well) and teflon brake pads. The teflon brake pads make it almost impossible to lock the rear wheels even under super high braking loads, perfect for a oneway use. Mugen makes them and so does Kyosho, you can easily adapt them with some mods to the R40.
With my braking setup I can brake very hard with the oneway setup and not spin out. Clearly not as hard as with a front diff of course.
#9821
Originally Posted by AMGRacer
You want a fairly stong brake servo no matter what diffs you are using, but more so with a one-way. What makes you spin out with a oneway is locking the rear tires, so therefore maximum braking is achieved when you are just before the lockup point. However that all assumes a nice linear force being applied to the brake disc, which with a standard servo and the stock R40 brake does not happen.
I need to get some of those teflon pads though. What are those part #'s. I would like to be able to use the brake some. Ive tried the s9451 on the braking side, still spun out to the braking was very dull. Same as my cheap s3003. But the throttle response was nice. Some truly cant stand slow throttle. I dont mind once Im used to either or.
Also how does your TRS work on the car with your strong servos. I know mine were impossible to pull back.
#9822
Welp, I think I'll definately get a nice digital servo for my R40. The hi 945 seems good, but...ehhhh...mehh...I'll get another JR Z9000s ! It costs $105, but well worth it. The urge to drive the R40 with the 30% is really growing...I must RUN! Snow is on the way for the weekend. Anyway, I didn't get the pexi glass since it was too expensive so I picked this up for $8 and all I need are guages. WOOHOO!!! Lastely, just need a tire truer though I got plenty of time. I pretty much go out for a run when I have time anyway as well as weather permitting.
#9823
Coreless is indeed much better for smoother motions. Most digitals are coreless for that matter.
I never use a TRS.
#9824
While building the transmission on my 2005 Edition R40 I seem to have stripped the two screws on either side of the clutch (one black one silver). Is there any way I can buy just those screws or am I going to have to buy an entire transmission assembly? I searched Tower and Buy HPI for the part numbers and nothing came up 94275 and 94276
#9825
Upon closer inspection, the screws do not actualy looked stripped at all, still nice little hexagons... however my 2.5mm alen wrench is too small for them and my 3mm is too big. Which is odd because I got them in the two speed clutch with the 2.5mm in the first place. I tried SAE sizes and get the same results, either too small or too big. Has anyone else had this problem before? Maybe I need to invest in a better set of drivers.
