HPI R40 Nitro Car Forum
#9706
Originally Posted by Rapid Roy
Some others have had a problem with the bell cranks lifting up on the shaft. This can happen sometimes depending on the angle of the turnbuckles. You should be able to see the problem if you do like AMG reccomended.
#9707
just try this. pop your side belt of, then take it for a run and try keep it in straight line, dont gas it quick. see if it fixes it. if it does give the diff a go over. if not look else were. i know it be hard to really tell. but hey anything worth a try. cheers.
#9708
It is quite hard to drive with rear wheel drive car (rear wheel drive 235mm cars have wider tyres) will turn to either way and probably wont be able go that far without spining out my belt came off during race once and it was just too hard to make the car go around the track so i called it quits.
#9709
For those of you with the TI screw set, are the heads hex or are they the heads phillips like the stock screws? Just wondering.
#9710
2mm Hex
#9712
Thanks for the quick reply.
#9713
what do you guys reckon about the stainless steel screws? as i just brought the kit for my car. cheers
#9714
Thanks for the answers guy's!
I checked almost everything you suggested allready
It's time to let the Local shop take care off the problem, one thing is sure for me tho...I NEVER buy HPI again! Not even replying on my 10+ emails to their support department so that sucks.
I think Serpent will be the best next choice, made here in the Netherlands and their plant just 3 minutes away from where i live...should have gone serpent at first but the R40 kit had nice specs and looked to be a solid car.
I'll keep this updated if the problem should be found ..
Greetz, Ron
Greetz, Ron
#9715
#9716
Greetz, Ron
Greetz, Ron
Every car has its issues. Just take a look at the 710 thread and all the stuff they do to that car. The customer support thing is puzzling though. I really can't comment too much on that since I am in the US. I usually come here first for any problems and usually get a pretty good response.
One last thought, have you tried disassembline the front end and rebuilding it? Make sure everything is nice and free as you are doing this. I have had steering binding issues from either overtightening somthing or a warped part or somthing being missaligned.
#9717
Originally Posted by GBagRacing
Hey Roy What was the fix for this problem as I'm starting to experience this on the LH bell crank. Should I shim from the bottom of the shaft or try from the top. Not sure if there's enough shaft to shim at the top though. I'm thinking there needs to be better mfg tolerance on the diff cover where it caps the bell crank shaft.
#9718
#9719
Greetz, Ron
Greetz, Ron
#9720
I just tried ordering from this site posted back a few pages.
http://www.fastnfuriousrc.com
I ordered the front and rear carbon fiber shock towers because they have them for %50 off. I selected the items and went to the checkout cart and saw that they wanted $14.50 to ship. The parts cost $20.10 together. Not such a good deal after all. I guess I'll give them a call tomorow and see if they will give me a better price on the shipping. For now I didn't complete the transaction.
