HPI R40 Nitro Car Forum
#6691
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
I'd like to know if this will be the new standard edition in the us...I guess no more "the car is to heavy cpmplaints".....
#6692
Originally posted by fastharry
thats a 3 racing brake arm....with a HPI throttle ball(the little brass ones thay have that go in the plastic arms on the carbs....the thread sise was 2-56).....and a ball cup from the racer2 linkage set.....
and let me tell you something....this cars brakes are great....they never cgange their feel from one lap to the next..wiat till I get the HPI stainless brake for it....
im sure that spring works much better than fuel tubing..
my brakes work ok, but I can't seem to get them tight enough..
if I do then they drag all the time..
#6693
I'm using the stock horn....
#6694
Originally posted by onnetz
also your not using the stock servo horn?
#6695
Originally posted by Artificial-I
You need adjustable end point transmitter then.
seems like I just dont have things setup right..
#6697
sounds good.. I've got a few days to do a complete tear down while I wait for a new front belt..
#6698
I can't find anyplace that has it...or the new belts...any ideas?...
#6699
hey AMG..got a web address for them?...thanks..
#6700
HARK
NSXSHOGUN
REGG151
check your e-mail for a videoclip
NSXSHOGUN
REGG151
#6701
http://www.rctech.net/forum/forumdis...?s=&forumid=87
#6702
thanks bud..
#6703
Hey klander I can't acces my gmail for some odd reason. Its pissing me off.
#6704
I went out today and it rained, but I ran the car anyway after a few minutes. The car ran great, but I need to know if I can use better upper rear links and ends, and steering linkages and ends. Anyone have a recommendation? The steering has too much slop and the rear linkages are too delicate. Now, this is coming from someone new, so don't take this into too hard of consideration if you are buying the kit.
A fellow racer down said that ride height should be set at 5mm, mine was set at 8mm. Doesn't this factor into long races since the tread of a tire wears down?
I notice that the rears tires wear down fast, I know this is normal, but should not be the case since I was running 42R/40F. Is there some overdrive built into the belt/pulley system?
Last but not least...droop. Someone said that I had too much uptravel, how are you guys setting this- measurements?
