HPI R40 Nitro Car Forum
#6424
I misunderstood your post about 50 pgs back then: i will stick the O-spring back on. what about the first shim behind the engine? Is this absolutely necessary on my nsr12?
#6425
Sweet, just found out my old car was in rcnitro. Or at least their website.
http://www.rcnitro.com/magazine/Nitr...des.asp?ID=153
I still have that body, have yet to run it. Still want to put some lights on it. I think im going to get this body ready to run soon.
Or maybe will just cherish it forever.
#6426
lol.
Klander- I ran the Rody V12 and it is unbelievable!!! .
The bottom end of the MT12 in no way comes close to this engine. A good firm tap on the throttle sends it 10ft+ easily. What I also like about it, is that it's not even maximum power yet and it is flat out fast! I still need to get diff fluid for the rear. What diff fluid are you and other guys running for the rear? Did you install the rear axle instead?
#6427
If you have the front one way try the locked diff or just something heavy 50wt should be good.
#6428
i am using 50000 silicon oil in the rear.
#6430
HARK- Yes, I use the solid axle in the front, it works great, but like I said before you lose some steering and the tires wear faster.
I use a small amount of light grease in the rear, no oil.
BTW I'll try sending the vid in a couple of minutes. ok
#6431
setup board - station
anyone using a setup board?
if so wich one and how do you like it?
#6432
HARK
REGG151
TURBO15
The video has been sent...
BTW here is a pic of my hpi racer 2
REGG151
TURBO15
#6434
yeah the reason I'm using that engine is because we have a stock category and you can't change the engine, you can switch gear ratios, suspension, pipes, header, but the engine has to be the hpi .15 stock.... lol it's a funny category to release stress from the rest jajajajaja... I think now they are letting us use foams, which work great cause I pass on all the worn tires that my R-40 can't use anymore...
