HPI R40 Nitro Car Forum
#4516
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Same motor, same clutch out of the MTX3 that did so well this past year, but it keeps running 30 seconds short of the 5 minute mark in the R40?
try running a bigger fuel filter also.....my car runs 5 minutes easy...even on bigger tracks......remember,theres alot of factors in fuel economy.....everything from weight of the car,to gearing........even how you drive each car differently....
#4517
Originally posted by AMGRacer
I have some caster clips you can have.
You can make this car brake ultra hard if you need to. You need a decent brake servo tho.
Cool thanks for that
I am using the Futaba 9550 for both steering an brakes... Only thing i can think of it is the graphite brake disc causing the problems?
BB
#4518
Originally posted by fastharry
if you think you have no brakes now,try the graphite ..seriously,though,my car has great brakes with a 30 futaba 3010(BTW,a GREAT throttle servo...)....and the car is not known for bad brakes,so you might want to go through the linkage's...
and speaking of linkage.....now that I think about it,you know when I got the best brakes?.....when I put that 3 racing metal brake arm on.........
See above post to AMGracer
BB
#4519
Originally posted by Bundy_Bear
AMGRacer:
BB
AMGRacer:
BB
#4520
stupid ?
OK, I dont want to sound like the ultimate noob but I have a question. I bought my car used and I didnt get a manual/tools with it yet(getting them next time I go to the lhs). My question is how do I measure toe in/out, caster etc. Is there an included tool or what?
Thanks Guys
Thanks Guys
#4521
#4522
Re: stupid ?
Thanks Guys
Thanks Guys
BuddyBear - are you running a front one-way? If so, you are giving up tons of break-action.
Good luck!
#4523
thanks guys, but are there any tools that are included in the kit that measure the caster, toe in/out etc?
#4525
Oh you have the graphite disk on yours?? I never used it but harry seems to think it is junk and I have no reason to believe otherwise. Whack the metal one back in.
Thanks to Robin dropping the orginal into me at work today i can give that a try
BB
P.S:
When can i annoy you for those castor clips?
#4526
Re: Re: stupid ?
Originally posted by JAG Racing
NItroRacer - Probably the most popular tool is th Hudy or Integy set-up stations. If you are on a budget, there are some crude methods.
Good luck!
Good luck!
No i run on the same concrete track as AMGRacer. At the moment i am using the front diff
#4527
Breaking Problems!!!
You guys: I just installed the one way diff case in the front. It works great on corners, but on the breaking now my cars spins out. I tried releasing the break a little so that it doesn't spin and it worked, but is there a way to improve the braking action with the one way like gluing it or something so that the front tires break as well???
#4529
ok thanks...
#4530
Maybe I can put silly putty on the stock one, or glue the inside to see if it works as a one way and to break with all 4's.
