Cleaning your pipe
#16
Originally posted by kevink2
Uh oh...help me, the evil Doctor Goldfish is prescribing a new shiney one..... cccan't.......... sssstttooooppp........... waaallet........ frommmm...... opening....muusstt stoppp iitt....mussstt sstooop....nooo noooooo!.
#18
Originally posted by B
WD-40 is a corrosive product
#19
Originally posted by TAW
Wd-40 corrosive, this is news to me. The WD stands for Water displace.
#20
hehe
how do you guys think WD-40 "cleans?"
all the polish are to "melt" away one very THIN piece off wutever u are polishing to give you the shiny surface underneath
WD-40, the thing will not "eat away" the car alive, jsut be careful to get rid of the thing if you are cleaning the engine with it, because if left with it uncleaned, it will slowly eat away the engine.
that is why i said be careful where you put it.
if i am wrong, someone correct me
#21
Originally posted by eddiethefish
hmmm... I use Armour-All on the plastic piece, though.
#22
Pipe Polishing
so be careful where you put it on your car
#23
Pipe Cleaning
Polished Aluminum can be very difficult to keep the bright finish clean and shiny. I always avoided it on my Full Size Car(s) for this reason. Too much work to keep nice looking.
I've used Oven Cleaner on my Satin finish Headers before with good results, but it would probably dull a polished surface.
Also seems like the Polished Pipes are softer and get damaged easier (anyone else notice this?)
#24
#25
I have read in the forum long long ago when someone wanted to use WD-40 as the after-run oil. All of the responds were a NO NO! Corrosive might be one of those reasons, but don't take my words. I just can't remember vividly what was the exact reason not to.
The only other negative I've read about it for use as an after run oil was that it was combustible...
#26
Re: FYI
Originally posted by EVOLUTION
http://www.wd40.com/Brands/wd40_product_info.html
CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape, stickers, and excess bonding material.
DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
LUBRICATES: WD-40's lubricating ingredients are widely dispersed and hold firmly to all moving parts.
PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
#27
I bought a cheap bench grinder ($25 I think) at Costco. With a cotton wheel and some roughe (sp?) In a about a minute... I can have my pipe looking better than new... It really is kind of handy... I polish everything when I get in mood...
#30
Kev, you are right, WD is not corrosive and is a very good rust inhibitor. FYI, one of our local NorCal racers who has been known for building some fast motors uses WD exclusively as after run. It is kind of an unorthodox methd but it makes sense. Once the fuel is run out, he actually runs the motor on the WD until all of the fuel is gone and flushed out of the motor. I have seen the inside of one of these older motors and they look great.
Jonathan, I have Steve's bench grinder/buffer and it never occurred to me to buff my pipe on it. I figured it would just get thrashed again the next race anyways
