The Chassis for your Nitro TC3!
#197
#198
#199
Hi fellow BMI's
Conversion nearly complete...
Only problem encountered.....Pullstart engine's don't fit...
Bump box here we come....
Hooked on what kit did you get...hope fully non pullstart....
RR kid i was running the hardcore but it's not in the same league.
Also recommend to use oem type battery pack saves a lot of grief
I also found futaba servo's a bit of a squeeze,throttle+brake servo mount needed a touch with a dremel
Thank's again gent's
Terry S
Terry S
#201
Originally posted by xray vision
Hi fellow BMI's
Terry S
Hi fellow BMI's
Terry S
#202
Registered User
I use the K- Factory Centax clutch. The gears are maybe alittle wider and you have to have about .040 end play in the clutchbell. The problem with mesh I had was second gear pinion was rubbing first gear spur. Not really a mesh problem. The mounts Jay made for me should cure the problems if anyone has trouble. I used Futaba 9303 Brake and Throttle servo and did'nt have to dremmel anything out on the chassis. I did have to space it up some so the wires fit the cut out in the chassis servo mount.
Hey xray, Real toy race cars don't use pullstart engines! LOL
#203
The only major prob I have is the engine mounts. I have to tilt them to mesh right, but then the screw holes dont line up. But the mounts the protc3 will send me hopefully will solve the problem. I must say that the chassis looks AWESOME when everything is on it. The pics dont do it justice. you have to see it in person
protc3. you got mail
#204
I want to make sure I am doing this right. On my controler I flipped my steering from reverse to normal. Otherwise since the steering servo is flipped it would go right when i steered left and vice versa. I kept the throttle the same
#205
protc3. were you able to recieve my email?
#207
Registered User
Sirrio 12 Smeltz mod, Richey MT Mugen RTO and RTU 12, and RB Concepts x12 5 port. All these engines take the same spacer on the engine for the K- Centax, thus they all work for me with the BMI engine mounts.
#209
Registered User
Probably yes Hooked! but not for sure!
