Old 10-27-2007, 02:04 AM   #1
gofastrlbrown's Avatar
Send a message via Yahoo to gofastrlbrown
Default Is There A RTR Dragster Worth Buying?
I was just wanting to see if anyone had any luck with any of the RTR dragsters, can they actually compete. Due to being handicapped it is hard for me to put a kit together. I thought another option would be to ask the community if there was someone reputable that would build me one and make a few bucks. Any advice would be appreciated. I know megatech makes a rail and a funny car. Does anyone know if either one of these products are worthy? Thanx in advance for any feedback.
Dip
gofastrlbrown is offline   Reply With Quote
Old 10-27-2007, 09:32 AM   #2
Taylorm's Avatar
Dip
..wonder if these guys could help you out? look like they have nice cars....... http://www.grandmotorsports.com/
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 10-29-2007, 01:28 PM   #3
griz11's Avatar
Send a message via MSN to griz11
Default Depends on what you want to do with it
The megatech's are fine unless you try and up the power very much. Running an OS .18 is about the limit to what you can do. Lots of them out there I started with one myself. GMS has excellent kits as does Walbern. I've had them both and recommend either one. Both have gas and electric kits.
www.teamwalbern.com
Griz
PRO MOtion FOtos
Racing Images
www.youtube.com/griz11 Photos are here www.pbase/griz11 www.elroyjetson.info
Canon 7D EF400 EF70-200 EF40 Tamron SP70-300
griz11 is offline   Reply With Quote
Old 10-29-2007, 01:41 PM   #4
joe of loath's Avatar
its not too hard to make one yourself. just shove a huge motor into a strip of 9mm plastic and put some big wheels on it. i was on a thread a while ago with someone making an eletric dragster.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 10-29-2007, 04:28 PM   #5
Building a drag kit is ALOT less painfull than building other kits. There is not to much to them. If you need help or advice, just PM me.
rc_freak is offline   Reply With Quote
Old 10-31-2007, 12:29 AM   #6
griz11's Avatar
Default Not quite that easy
You might have something that will go down the track doing it that way but you probably won't win much if any. There is development that goes into these cars just like any other car. GMS and Walbern both have multiple titles and many wins. With a rail stiffness of the chassis is very important. You want it to bow slightly when you hit the power then level out. The bow helps keep the front wheels on the ground and also like a real dragster gets it moving faster. You can run pretty much anything in bracket class but once you step up to top fuel, pro mod or funny car its a whole different deal. Most of the guys you find in drag racing have done all the other forms of racing as well. Many of them are very experienced with modifying motors and such. If you never win at all you will still learn a lot about getting the performance out of a motor and chassis. It all looks so simple from the spectator's point of view but when you are actually racing its not such an easy deal. The Walbern door slammer chassis has several ways to build it. Solid bottom plate 2 piece bottom plate aluminum and carbon or straight carbon for instance. Engine in the regular place or moved forward. Unless you have a prepared track to run them on they are pretty much useless. In a parking lot forget it. They will just spin the rear wheels. And since you have practically no suspension it needs to be smooth and pebble free. This one has a Walbern 2 piece chassis OS .18 TZ modified motor and RSP '41 willys body.
The kits aren't totally complete like you are used too. Some of the stuff has to be constructed by the builder. Servo mounting for the steering servo. Linkage for the steering. Fuel tank mount and tank.
And this little number is my top fuel car.
And my funny car which is electric and based on a GMS chassis.
The willys pro mod is the only 1:10 scale dragster to ever grace the pages of Hot Rod magazine.
Griz
PRO MOtion FOtos
Racing Images
Worth buying a Hyper 8 Pro with 8.5 on the horizon? Cain Nitro Off-Road 10 08-02-2007 01:08 PM
Is buying this 15 dollar air brush kit worth it? adr3naline fix Painting, Designs, Graphics and Photography 9 08-30-2005 06:35 PM
SAVAGE or RPI MT2 or anything you think is worth buying??? T-Maxx Matt Electric Off-Road 5 10-31-2004 06:03 PM
TRF dampers, worth buying? MrRolla Electric On-Road 3 04-13-2004 09:39 AM
Is Stadium Truck Worth buying in S'pore Catch22 Singapore R/C Racers 3 07-22-2003 12:26 PM
