Kyosho Evolva M3 >
Kyosho Evolva M3
Kyosho Evolva M3
Old 02-08-2011, 12:29 PM
  #901
Richard E's Avatar
The markings (20,10) on the evolva fuel tank show the cc's of fuel that is still in the tank.
So this is your check point for fuel consumption in case you need to run 5 minutes and try on different carburator restrictors, exhaust pipes and/or headers and so on.
Richard E is offline
Old 02-08-2011, 03:55 PM
  #902
RB|PoweredShimo's Avatar
RB|PoweredShimo is offline
Old 02-18-2011, 03:33 AM
  #903
the exhaust tip doesn't seem to reach the edge of the body so oil will go all over the RL tire and other parts attracting dirt and god knows what.
Is there a way to solve this issue without using silicone exhaust extension as i know they alter the engine revs making it not perform as well since it will be a bit restricted.
speed6 is offline
Old 02-18-2011, 05:47 AM
  #904
Trader Rating: 41 (100%+)
I haven't had that problem with oil and debris as long as I have not set the engine too rich. The exhaust and oil on the track builds traction. The tires love it. But, you can lengthen the little arm of the pipe hanger to move the stinger outside the body.
davidl is offline
Old 02-18-2011, 06:43 AM
  #905
rjr
When you cut the body for the exhaust, don't cut a hole. Make a flap by cutting a "U" shape as if the "U" is laying down to the right. Then fold the flap back so it directs the exhaust out the body. Some exhaust will still get by the flap and on the inside of the body but most will go outside.
rjr is offline
Old 02-19-2011, 08:53 AM
  #906
Hi Guys
Can you please explain to me what the below settings mean and where are they located, sorry but i a new at this
Rear Setup
Body Mount Angle
Centre Post Position
Body Mount Height
Matthew
Teamcastagna is offline
Old 02-20-2011, 05:34 PM
  #907
GMartinez's Avatar
Trader Rating: 91 (100%+)
Originally Posted by Teamcastagna
Hi Guys
Rear Setup
Body Mount Angle
Body Mount Height
Matthew
Body mt angle is located on the rear body post there are 3 positions to choose from inside setting has less rear dynamic the mid & the outside setting will give you the most
center post position is also best used center location which is the neutral postion of body travel
body mt ht is the 2 screws that is mounted onto the rear body mt the higher the screw the more dynamics of the body giving more steering,rear bite but can also make the car more twitchy n aggressive so you can adjust the settings more to your liking
GMartinez is offline
Old 02-20-2011, 06:41 PM
  #908
Wow...Great collection of images.
henrykipson is offline
Old 02-21-2011, 11:01 PM
  #909
Originally Posted by occ
Good eyes! I didn't notice that.
I wonder if this new 2-piece upper deck is part of the upgrade.
He also seem to run a pressure chamber with a clockwise to anti clockwise twisting to aid in the turns.
Also at the bottom rear there are like body post to the side of the body maybe for reinforcment?
speed6 is offline
Old 02-21-2011, 11:13 PM
  #910
Originally Posted by HoboShop
Sorry I got back to the house late.
Here is the setup
Front
shock oil 500
spring white
shock pos H
scrub set 1.0
caster normal
camber left 4 right 4
toe angle 1.0 out
front width 252mm
droop 0 mm
antiroll bar flat across
tire hardness 32
tire diameter 67mm
ride height 6 mm
scrub set 1.0
Rear
shock oil 500
spring white
spring pos middle
scrub set 1.0
upper arm short/in
camber right 6.5 left 6.5
toe angle 3.0 in
rear width 260 mm
droop 9 mm
antiroll bar stock
tire hardness 35
tire diameter 74mm
ride height 7 mm
sus holder B
rear hub axle / mid /
rear wheel base long
Clutch setting 0.8
Servo Saver position A
lock tight everyting that screws in to metal except the screw that goes in to the top of the radio tray that screws in to the servo saver.
Ti/9mm ball screw set
vzw024v
For the Front can you kindly confirm the following
Knuckle Arm Axle Low, Mid or Hi
For the Rear
Shock position you said center that means on number 1?
Body positioning setup as the manual describes?
speed6 is offline
Old 02-21-2011, 11:24 PM
  #911
Originally Posted by GMartinez
Here is a quick setup guide
track width Front 253 Rear 264
droop front 0 Rear 9
stock springs
Camber front 2 rear 4
toe front 1 rear 3.5
tire Front 32 Rear 35 tire size Front 67mm Rear 74mm
Shock oil bumpy track 500 smooth 600 all around
the rest is stock setting as the manual instructs?
thanks
speed6 is offline
Old 02-22-2011, 03:00 PM
  #912
GMartinez's Avatar
thanks
yes just insure you check your shock shaft length f&r after you set your droop to ensure it is not changing the setting when you re-connect your shocks same as for the sway bar all drop settings should be correct when you re-install the sway bar,shocks
Old 03-05-2011, 05:57 AM
  #913
Default more grip
Hey guys today we went for the 2nd Testdrive but the track we race at is quite often very dirty so we where drifting heavily in the corners.
I thought of going for softer springs allround and maybe 40 / 45 oil all round instead of 50.
What would you you recommend?
speed6 is offline
Old 03-07-2011, 11:59 AM
  #914
GMartinez's Avatar
Just ran my fresh M3EVO this weekend very similiar conditons heavy pollen but overall car was really good might try softer springs this weekend stock springs/oil longwheel base set up
Old 03-08-2011, 02:10 AM
  #915
Default Softer Springs for the M3 Evo
Dear all, can you kindly confirm part numbers for a one step softer shocks than stock.
Just to confirm if these are the ones
FM531-4019 Front Spring (4.0 – 1.9)
and
FM532-5020 Rear Spring (5.0 – 2.0)
or
FM532-4519 Rear Spring (4.5-1.9)
speed6 is offline
