GT class--buggy-based on road!
#6182
Guys,
This is for a friend in Peru.
He is using a DM SPEC with offroad .21 engine.
The thing is that, based on what he is explaining me, it seems that the 2 speed setting springs get warm/hot and softer after couple minutes of run so at start the shifting point seems perfect but after couple minutes it starts to shift early and early as the springs gets softer ...
Any tip to solve this ??
thanks in advance guys ...
Pat
Pat
Hey Pato, if the tune is correct then the springs can be suffering from fatigue. This could be caused by several things but most of the time is by over adjusting the screws. This causes the spring to colapse on itself and then the spring becomes incosistant. I would try new springs and being very carefull not to over tighten them, specially when new. What I do is use the smallest driver (in diameter) posible so I don't overtorque the screws. Then I unscrew them. After a couple of tanks I set the screw again and this should be set without any problems. Let us know how it went so we can learn from him as well.
#6183
#6185
...it looks like nothing important...but it's there and works for me.
#6188
#6190
so did anyone see the article in july issue of rc driver?
Tony Phalen took a L8ight and a tekno v4 chassis to make gt car.
yes this is the easy route as apposed to the custom work done on this forum.
i will post the pics of the 777 buggy conversion soon as i sent them to greg vogel...he is racer from my area as well as the editor of driver. they really enjoy custom versions of cars as seen on this forum.
so with that said i have a losi buggy tekno v3 chassis collecting dust because i received the 8ight-e 2.0 and was thinking of converting it to a gt car as well, i found the p/n for the front n rear shock tower but need the bumber n rear body mount....does anyone know the p/n for those 2?
#6191
Tony posted pictures of his car awhile back, very slick and very fast from what I understand.
I would sell the 777 stuff and go Losi unless you want to race in a nitro class (I suspect Losi is working on a car with a 2 speed already.)
#6192
#6193
5mm too short i have used a cvd from the losi lst that fits though, sorry idk the part #
