MRX-4X
#692
I see on Ralph's setup that it lists a Jaco 32 front tire. I have wanted to run the 32/35 tire combo and use Jaco on my 1/8th but they don't have a 32 compound listed as one that they offer. They only seem to offer a 30 or a 35. I think Jaco needs to get rid of the 30 and make a 32 front tire. That would be great.
#696
The part# for 32 front's is JAC3732P (prism wheel).
Whats up Doc.? The hole in the X up rite that the set screw 3X16mm screws into has been moved in toward the center of the chassis 4mm, shortening the length of the upper arm center to center. The X up rite with both of the bearing shims on the "inside bearing" still has the center of the contact patch/ traction circle .5mm further away from the center line of the lower pivot balls. The simple...4 or R up rites will produce more rear grip.
#697
Jaco does make 32's but no one seems to carry the things. They can be hard to come by sometimes. 32/35 really works well at a lot of tracks.
