Mugen MTX-2
#2581
Originally posted by gooseman271
Alright, I turned out the bottom ball, but now there is slop in the wheels. Are the balls suppose to lock into the hubs, or is the loose play just the way it is?
With your question, yes, they will have some slop. The pivots need to rotate freely or your suspension won't work. I spent endless hours trying to get them slop free and still allow the balls to pivot easily, never could achieve this. Alittle slop will not hurt.
Im not sure what your actually what your actually adjusted, the pivot balls when adjusted will not change the slop, its the only the retainer that do (ie the large hex type that requires the large allen key to adjust)
#2582
Actually nevermind, i'm stupid, I was missing some extra parts. Got it figured out now, thanks.
#2584
guys
I know that I need to use a digital caliper to set the kawahara micro centax.
What else do you suggest in way of building this?
And also the kawahara negative diff what diff oil to use
and what setup for the whole car you have found to be the best starting point.
using foams on a very smooth aspalht.
no traction compound though on the track.
#2585
Originally posted by Sydewynder
Tommy which 2 speed? The K, 2 shoe one? I'm not saying it will or it won't but it will.
If the MTX-3 tranny will fit the MTX-2, it might give me some different gearing options as well.
#2586
Originally posted by Super38
guys
guys
#2587
thanks teksrq,
how about the micro clutch any special way of building it?
is there a thing I need to watch out for when building it?
#2588
tersq,
it's the shaft buddy.
I had the same problem. The shaft material is too soft.
I was lucky to find a replacement shaft, but I'm looking into an alternative solution.
Also, the bearing in the second gear bell is crap. Replace it and it will be much better.
#2589
thanks teksrq,
thanks teksrq,
#2590
Originally posted by Novarossi
Let me guess ..... The little concave plastic spacer that goes inside between the pivot and retainer - I always do it
#2591
Re: tersq,
#2592
Once you got the two spur gears off, you'll see the damage with your bare eyes (if it's as bad already than mine)
The one-way bearing wore a groove in the shaft so bad, that I couldn't get it off anymore.
Try Castle Hobbies (RC Imports), they are the importer off Kawahara. They usually have spare parts.
#2593
Originally posted by tekrsq
I'm hoping the MTX3 tranny will fit the MTX-2. I've got the Kawahara 2 sp on it now, but I keep having problems. First, it developed a "wobble". Almost like the shaft had worn down were the bearing rides. I was in the process of figuring whether the shaft was worn or the bearing race had worn down, when the damn bearing in the housing seized on me. I'm thinking (right now) hopefully it was a bearing problem all along. So now I just ned to get the bearing out and replace it to make sure.
#2594
Re: tersq,
#2595
Originally posted by dtm
Now you really don't want to start that off AGAIN!!!!!
