Old 05-02-2003, 09:27 AM   #106
popsracer's Avatar
fastharry;
Unless they've moved the Receiver mounting, I WON'T be getting one soon. One side hit and your day is over. I honestly can't think of a single race where I haven't been side impacted by SOMEONE once during the day.
tony montana;
Yes they will fit.
popsracer is offline   Reply With Quote
Old 05-02-2003, 11:53 AM   #107
td-civ's Avatar
Trader Rating: 18 (95%+)
Default Re: jason102276
Originally posted by THeGame
I got the Team Only kit.. I dont like the Centax cluch at all. ITs still in the bag.
do you want to sell your cluch
td-civ is offline   Reply With Quote
Old 05-03-2003, 07:22 PM   #108
tony montana's Avatar
Trader Rating: 66 (100%+)
popsracer do you have part#'s for the v1r pullies and belts?
tony montana is offline   Reply With Quote
Old 05-03-2003, 07:38 PM   #109
hey guys, i have a reflex roller if someone is interested. just needs a fuel tank. got pics if you need. $180 takes it. [email protected]
compuatic is offline   Reply With Quote
Old 05-03-2003, 07:44 PM   #110
popsracer's Avatar
Guys;
The part # for the Pulleys is a few posts up and the PN for the belts has be posted several times in this thread. I'm sure if you read back a few Posts you can find them.
Old 05-03-2003, 08:45 PM   #111
td-civ's Avatar
just when out for a test run with the new car i got its running ok but need to work on the two speed on it need help
Old 05-04-2003, 02:13 PM   #112
td-civ's Avatar
Default servo
what kind of servo do you think is the best for steering on the reflex with a jr r1 controler
Old 05-04-2003, 03:26 PM   #113
popsracer's Avatar
Default need help two speed
td-civ;
Set-up the 2 spd exactly as the Manual recommends, then adjust the shift point screws 6 turns out to start with. A 1/2 a turn either way after that should get you where you need to be.
If you playing in the Street, just about any Servo will do. For Serious racing a High Speed Digital is the way to go. Keep an Analog servo for the Throttle/Brake and stay away from the Hitec (5)625/645 series Servo's. I've had 3 that have been NOTHING but trouble.
Old 05-04-2003, 08:35 PM   #114
mitch179's Avatar
go for a KO PDS 2143 FET servo.. thats what i have and it works sweet super fast (0.08sec) and 8kg's of torque
mitch179 is offline   Reply With Quote
Old 05-04-2003, 10:57 PM   #115
THeGame's Avatar
Send a message via AIM to THeGame
Default popsracer
are you using the Trinity pinon and spur gears on there centex ?
What all do i need I'm gonig to try it..
THeGame is offline   Reply With Quote
Old 05-04-2003, 11:26 PM   #116
popsracer's Avatar
Default Mugen Centax on the Reflex
THeGame;
The MTX-3 Centax kit comes complete except for the Pinions and the Mugen and Reflex pinions will both fit. The 1/8th Pinions have the same tooth pattern as the Reflex, the MTX-3 pinions are "Different" but will work.
No matter what, I would space the 1st gear Pinion out to mesh fully with the Reflex Spurs.
To do this you will need some kind of spacer. I used an Aluminum Oil Pan Gasket washer and ground the OD below the tooth level of 2nd gear. (was just my preference)
The person who told me about the MTX-3 clutch and says he uses it with the Factory Pinion spacing and has never had a problem. I also needed more total shims than were included in the kit, so you may too depending on your flywheel spacing.
Use the Centax Clutch set-up instructions on the Team Trinity website. They were spot on perfect for me.
Old 05-05-2003, 05:19 PM   #117
td-civ's Avatar
how much do they go for
Old 05-05-2003, 05:35 PM   #118
mitch179's Avatar
i got my KO servo for 147 AUD delivered from hong kong so i guess it would be something like 80 maybe 90 USD.... depends where you look for them but they are worth every cent trust me!
Old 05-05-2003, 05:38 PM   #119
td-civ's Avatar
ok and how about for you gas and brake servo
Old 05-05-2003, 05:41 PM   #120
coastaltony's Avatar
Got a 1/3 built Reflex for sale, $200.00
coastaltony is offline   Reply With Quote
FS - TRINITY REFLEX TEAM ED & REFLEX NT CARS MUST GO!!!!!! Big Reg Australia For Sale/Trade 7 03-09-2008 10:42 PM
Trinity Reflex 12 fuelgun R/C Items: For Sale/Trade 11 01-17-2006 09:16 PM
Trinity Reflex 12 TheTurtleMan Electric On-Road 1 01-04-2005 06:35 PM
FS/FT Trinity Reflex Cosmo R/C Items: For Sale/Trade 3 04-09-2002 05:08 AM
Anyone into the Trinity Reflex? vanntz Singapore R/C Racers 5 04-08-2002 10:10 PM
