need help on my pull start car >
Old 04-14-2007 | 06:02 PM
kyosho 444's Avatar
Default need help on my pull start car
i tried starting my car but the pully was hard to pull when my glow ignoitor was put in it did not turn over i tried to tune it to start it and changed the plug we also put after run oil in it plz help me
kyosho 444 is offline
Old 04-14-2007 | 06:06 PM
Your engine is flooded. Take out the glowplug, turn the car upside down, pull the starter cord a few times. Then put the plug back in and you should be fine.
meinie is offline
it's flooded...take out the glow plug and pull it a few times to clear it out. Then put the plug in and try again.
Dredd is offline
Old 04-14-2007 | 06:20 PM
kyosho 444's Avatar
thanks ill try that.
Old 04-15-2007 | 01:07 PM
Wayne1one's Avatar
you said what type of car should I get pull start etc. that was quick, you already are having problems starting the car already
Wayne1one is offline
Old 04-15-2007 | 09:16 PM
kyosho 444's Avatar
ya
Old 04-15-2007 | 09:21 PM
Serpentd's Avatar
Dude, I think your engine is shot!! You need to go and buy a new $400 dollar motor now because you put after run oil in it. So just throw that motor away and buy a new one. But if you don't spend over $350 dollars then it will happen again. So don't buy a cheap motor. You might need a new car as well. I would buy a new Serpent 835 because they are so popular right now! Good luck and let us know how things go! Later.
Serpentd is offline
Old 04-15-2007 | 09:28 PM
kyosho 444's Avatar
ok thanks im getting a kyosho v one rrr evo
thanks for all the help guys
Old 04-15-2007 | 11:08 PM
Serpentd's Avatar
Dude, you realize I was only kidding about your engine. I'm still not 100% sure if your for real or not. Don't throw anything away if you really own it!! I appologize if I was wrong about you. Sorry dude.
Serpentd is offline
Old 04-15-2007 | 11:14 PM
Team Kamikaze's Avatar
You are funny
Team Kamikaze is offline
Old 04-16-2007 | 09:15 AM
JVT MTX3's Avatar
Kyosho,
Buy your kit from Team Kamikaza, they have the best price I've seen anywhere on this planet!!!
JVT MTX3 is offline
Old 04-16-2007 | 01:12 PM
kyosho 444's Avatar
thanks to all of you guys im trying to get the engine fixed almost done guys
and serpent its ok i still have my engine
Old 04-16-2007 | 06:16 PM
Fred P's Avatar
Registered User
Dude get rid of the pull start you'll get stiff muscles yankin and pulling that damn thing!
Fred P is offline
Old 04-16-2007 | 06:20 PM
kyosho 444's Avatar
i just got it started
Old 04-16-2007 | 06:59 PM
Serpentd's Avatar
What kind of motor is it and what type of car is it in now??? Are you going to run this engine in you new sedan when you pick one out, or are you going to get a new engine too? Be sure not to run your engine too lean, or it will be shot bro, and this time I'm not jokng. Make sure when you rev it up it has plenty of blue smoke coming out of the exhaust. The blue smoke is the oil going through the engine. The more smoke, the more oil and the cooler your engine will run. But you don't want TOO much smoke, that means your engine is running rich and you will loose perfomance, but this will not hurt the motor. If you have little or no smoke, then you rist burning up your motor. Keep an eye on it. It's most evident when you give it gas out of a corner. Good luck man!!
Serpentd is offline
