Mugen MTX-4R
#1831
Hi
I am in the process of building my Mugen MTX4-R and have a few questions!
1/ How long should the front and rear shocks be? I have searched high and dry in the manual and it is not listed at all. I want to try and reduce change of tweak!
2/ What about the distance for the pivot ball between the knucke and the arms for both front and rear for the wheel track?
Also, for the servo horns do i need anything special? Or could i use some from another kit?
Thanks in advance and i look forward to your assistence!
RB_Racer
RB_Racer
#1832
Can anyone assist???? I want to make sure i have full suspension travel?
#1833
Hi
RB_Racer
RB_Racer
1. Dun remember seeing it in the manual saying how long it should be. But i think as long as the end of your ball joints cover the threaded portion of the shaft would be sufficent. If you are particular, just make sure the the rebound distance is about the same when you are done with the shock building.
2. This depends on what is your track width settings. Stock setting would 199mm front and 200 mm rear. You would just need to adjust till it the same for the left and right but still within the track width.
Hope this helps
#1837
I will be buying a MTX4R sometime this week
Anything new? Tips, tricks?
I cant wait!
I cant wait!
#1838
Hope this helps
Hope this helps
#1839
#1840
Also make sure that you use the correct shalfts for the front and rear, as they are different lengths!
#1842
was anyone running a mugen mtx4r or a mtx4 at the great lakes challenge i was wondering what kind of 1st and second gear and spur combo people were running thanks
#1843
