Rounding the edge of foam tire after cutting? >
Old 01-10-2007, 04:33 PM
Trader Rating: 52 (98%+)
Default Rounding the edge of foam tire after cutting?
Rounding the edge of foam tire after cutting? is this necessary and what will this do vs square edge? Thanks.
straightaway is offline
Old 01-10-2007, 04:35 PM
rmdhawaii's Avatar
Josh Cyrul colaborated on an article about truing tires in Xtreme RC Cars which explains the difference between leaving it square and rounding it off.
True Foam Tires
http://www.rc411.com/pages/howto.php?howto=25&page=2
rmdhawaii is offline
Old 01-10-2007, 05:05 PM
Ivan Dickson's Avatar
Trader Rating: 32 (94%+)
Thumbs up
True Foam Tires
Great article very helpful
Ivan Dickson is offline
Old 01-10-2007, 05:37 PM
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
Anyone know where one could get a "SnakeSkin" File for rounding these corners? I have been looking for 1 for over a year now. A buddy of mine has 1 but he has had it for years and doesnt know where to get 1 now.
GrandeGixxer is offline
Old 01-10-2007, 06:04 PM
lil-bump's Avatar
Trader Rating: 89 (100%+)
The best I've seen is called a tungston carbide embedded rasp. Mcmaster-Carr sells them for about 24.00. Go to their Web-site
http://www.mcmaster.com/
pg 2543
lil-bump is offline
Old 01-10-2007, 06:12 PM
Default Thanks guys
Thank you for the info. It is very helpful.
Old 01-10-2007, 06:19 PM
Snowy's Avatar
Trader Rating: 15 (100%+)
The Border On-line shop in Holland sell the "SnakeSkin" file. Not cheap but well worth it!
Click here
Snowy is offline
Old 01-10-2007, 06:33 PM
lil-bump's Avatar
Looks like simular to Mcmaster carr tungston carbide rasp; but smaller; not sure what grit the snake skin file is.
lil-bump is offline
Old 01-10-2007, 07:19 PM
The McMaster one says the combination file is 46 grit and 80 on either side. Thanks for the link, I have looked at McMaster for it before, but did't find the right page I guess. I will be ordering it soon!
Old 01-10-2007, 07:40 PM
bsmooth's Avatar
Trader Rating: 18 (100%+)
You could make your own by getting some (free) paint mixing sticks from Home Depot, some sand paper w/ adhesive backing, and wrap it around the stick.
-Steve
bsmooth is offline
Old 01-10-2007, 07:51 PM
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Or just fold the sandpaper a couple of times and itll be plenty stiff. Sandpaper likes to melt the tire , where as files seem not too.
I even just use simple dremel rotary bits on my tire. Small and easy to work into a tight tire truer spot.
Artificial-I is offline
Old 01-10-2007, 09:08 PM
nitrothugg's Avatar
Thumbs up
if anything, thanks for introducing me to their site. i get their mag but have never thought about going to their site until that link was posted. man are those girls hot.
nitrothugg is offline
Old 01-10-2007, 09:09 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
metal file from home depot does the trick
Marcos.J is offline
Old 01-10-2007, 10:36 PM
Lil Paul's Avatar
Default Nope
You guys need to goto www.bvmjets.com, and click on perma-grit tools. Touring guys want a F-101, and the 1/8th scales racers need F-102. Those numbers represent fine and coarse. They work well, are very easy to pack, and best of all cost about 10 bucks.
Lil Paul is offline
Old 01-10-2007, 10:38 PM
Lil Paul's Avatar
Default ????
When I said pack in my last reply, means they are very thin, and can be placed anywhere when travelling.
Lil Paul is offline
