How do you clean and tune your ball bearings?
#16
guys, i just used the WD40 method to clean all my bearings last nite. well, it work out great. thanks, but those WD40 makes me headache coz i have to spray into a container, shake it, then spray each bearing to get all the dirt out. keke.. it works, not as difficult as it seems, but yes, its very time consuming, but heh, u have to take care of the car, so that the car can take care of u when u are at track rite? cheers.
#17
Location: Cebu City, Philippines and Ocala, Florida, USA
Well, I also use WD40 to clean my bearings. I usually soak them for about 30 mins and let all the dirt settle at the bottom of the container. Again, I repeat the procedure until there is no more dirt that settles at the bottom. This has worked great for me. After doing this, I lube the bearing with LRP bearing oil
#18
Originally Posted by Inferno
How many people use the RPM bearing blaster? Are they worth getting?
Cheers
Cheers
Not necessary if you have rubber shield bearings..... you can peel off the shields with a needle.
