Fail Safes
#61
Originally posted by simonfdr
My failsafe is so far a waste of $20.... =) Its like Insurance (Incase Sh*T Happens, its practically useless)
it will be there for you when Sh*t happens.
If it hasn't happened yet, I guess you're
lucky because experience tells me that
it is bound and it will happen sometime,
somehow, somewhere...
Like you said, it is like insurance. And the
fact of reality is, we all do not appreaciate insurance
until you run into mishaps. Nevertheless,
it sure feels nice to have that one sense
of security knowing you have a $20 thing on your car that
can save you at least $40 worth of damage or even
more...
Plus, I think it is well worth it to waste
$20 to cover your $300 to $2000+ investment.
Just my 2 cents..
#62
LoL something did happend and the fail safe was not there to save me. The battery popped out. All i needed was a $3 Return spring.
#63
Originally posted by jwf-ronni
Nevertheless,
of security
Nevertheless,
of security
to give you the second sense of security..
The fails safe is one
and the spring is #2
#64
I heard the spring kills alot of batteries... also my servo only has 50 oz torque, can it handle it?
#65
#66
Hm.. I might just get one now.
#67
any servo should easily be able to open the carb against a return spring
as far as battery drain i dont see it as an issue at all
i run 2 digital servos in each of my cars i ran the mtx-3 for over 1 hour this past weekend without charging the reciever pack and it is only a 730mah pack most of you use 1000mah or 1100mah
#68
#69
Dynamite failsafe
The black Dynamite failsafe should work on any radio except for the M8, the blue Dynamite failsafe is M8 specific. The Venom supposedly works on all radios including the M8.
#70
For NTC3 owners,,
Here's a pic of how I mounted the M8 specific Dynamite Failsafe.
The pic does not show the failsafe but if you check out the green led then you can imagine that the failsafe is mounted to the actual top cover of the receiver box. I drilled a hole for the led and one for the pushbutton and one for the 1 touch set up. I then covered the receiver cover with some thin alloy sheeting I had laying around and hand polished it to a mirror shine.
#71
Pics of Venom Failsafe
Here's the Venom failsafe mounted inside the T-Maxx raceiver box.
#72
have you tested the venom failsafe
i had read some people had problems with them
i havent decided which to get but i am leaning toward the KO since i have their radio equipment
#73
Edit-
The servo does twitch a little when you move the trim up or down when the fail safe is being used. Its nothing major though. I noticed it while useing the S-pos on my radio.
