What Radio kit?
#16
You only need two digital servos if you're using HRS mode. If you're in PPM (regular FM mode) you can use a combination of analog and digital, or even just analog.
I believe the new Futaba DSM system allows you a choice of using either PPM or HRS. As suggested, go to the thread in electric onroad. It's very good.
I got the 3PK super (synthesized version) a couple of months ago and love it.
#17
Couple other things. If you do decide to go with Spektrum there are two versions for the 3PK: the newer Pro version (which doesn't require digital servos) and an HRS version. The HRS version is faster but I doubt the average club racer would notice a difference over the Pro version.
As for the cover, you don't have to modify it if you're buying a 3PK super, that was only on the older radios.
#18
KO
#19
thanks again for your inputs
in rc mushroom they have ran out of 3pksuper with spektrum:
http://rc-mushroom.com/product_info....ducts_id=10452
so if i buy the 3pksuper 40mhz:
http://rc-mushroom.com/product_info....ducts_id=11272
with spektrum DSM system for HRC module
http://rc-mushroom.com/product_info....ducts_id=10352
would it be the same as buying it in a set?? i know i woiuld end up with another reciever and module, but would it still need modifications? or would the module in the transmitter just pop out just like that??
thanks, hope to hear from u guys soon as im desperate to get one
#21
I own the 3pks
have tried the hrs synth
spektrum hrs
and spektrum pro
I use spektrum pro now because some of my cars use analog servos..I can't tell if one is faster than another, they feel the same to me..
also I like the fuelproof coating on the spektrum pro recv
spektrum hrs
and spektrum pro
#22
dont think the clip fits over my spektrum on the 3pks...or are you talking about the unit fitting in alltogether.
im just talkin about the whole transmitter unit fitting in correctly
but i fink it does from comments
hopefully im not wrong
#23
and if i get the 3pks 40mhz transmitter and reciever
is it possible to remove the 40mhz modele on the transmitter and put a spektrum into the trasmitter?
#24
good luck and happy glitch free racing
#25
yea i agree you should hold the radios in your hand and see how they feel
