Rossi R12 Pixy
Rossi R12 Pixy
I should have stopped fiddling when it was working
Does anyone know the base carb settings for the Rossi R12 Pixy, model 163 R12, 3 port turbo on 16% fuel.
RC_Alan
The engine was new for this season, but it had probably been sitting on someones shelf for some time, it's not the latest technology I know.
I would like a new motor but there are only 2 more rounds of the BRCA rubber championship to go, I will get a new one next year I think.
I would check the crank as the engine comes in 2 models, the pixy and the pixy black. The one I had was a pixy black and had a non BRCA crank so I couldnt use it for the nationals
Cheers
Cheers
Originally Posted by rc_alan
Try 5 turns out on the high speed needle and 3 on the low speed needle.... I hope you didn't mess with the mid-range needle at all... If you did, set it flush with the carb body... With the hsn at 5 turns out and the low at 3 turns out, you'll be alittle rich... Tune the low speed needle first... Then set the high... Teamtrinity racing used to have a help page and the carb base setting there, but they've since changed there page and don't sell that motor anymore... The Rossi Pixy's carb is easy to set and holds it's settings very well... One thing you should consider being that the Rossi Pixy has been on the market for over 4 years now... And not saying yours is 4 years old... Is getting a new motor... .02
RC_Alan
RC_Alan
haha dude its not a .21! 5turns out is so rich it wont even start!
Cheers
RC_Alan
Originally Posted by ziggy12345
5 1/2 turns is right for me. 5 is too lean
Cheers
Cheers
RC_Alan
