Mugen MRX-4R
#871
Originally Posted by gashuffer
Are you guys using the rear swaybar at all on high bite tracks? Was at rev's this weekend and my car was traction rolling like crazy, I loosened up the sway and it helped some.Should I run without it?
#873
Originally Posted by iwk2much
You have a PM.
Are you going to SPEEDLINE?
#875
downstop question
hello
im trying to get a good starting point on my car
i race at a high grip vht prepped track with a long sweeper and some short tight turns.
when i set the downstops up with the fctory setup of 0 front and 9 rear the car has huge amounts of droop, so much that the springs loosen from the shock.
im running my tires 1mm smaller than the standard. what do you guys have your downstops set at? with the stock setup the car understeered like mad on throttle
#876
I'd recommend using the sway bar on the car... Not using it seem to help but you may also find the car not rotating around the corners nicely... It will almost seem like its "Squaring up" as oppose to having smooth corner rotation.
We were at Rev this past Sunday too. Please come and see us so we may help you under those conditions. My name is Ron and I was pitting with Mike Strack. Our cars ran pretty well with no Traction Rolling Problems (provided we stay away from the burms, ofcourse )...
As soon as we have an Editable PDF File, we would be able to post full set ups..
We should be there again on March 11th.
See ya!
BTW, good job getting 1st in the A.... especially for your first time out there!
The Airtronics Race should be a good one !
#877
Originally Posted by mrgsr
hello
#879
Gashuffer,
I would if I where you take the time to talk to Ron, the guy practicaly lives at Rev
#885
Mike Swauger - Is your setup for the MRX4R posted anywhere?
I race here in St Louis with Drew and the rest of the crew at Evolution. Trying to get the car ready for the season and wanted to completely rebuild the car. Thanks for the help.
Greg
Greg
