Mugen MRX-4R
#526
front and rear belt? do you guys set this thing tight or stock(loose)?
#528
i have tried to start with the tighter setting but i found my belts were stripping out faster.
i think they need a little slack to absorb the sudden shock from quick starts or punching the throttle out of a turn.
good luck!!
#529
Originally Posted by MugenDrew
When they go in the car there tight. After a run they will have some slack in them. I believe both of my eccentrics are in the or tmiddle position rubber belts. Are you having troubles?
thanks for the advise.
#530
Start with the middle setting. I have this to be a very good balance. The belt is a little tight, but not to the point of slowing down your drivetrain.
#531
Also, this may sound crazy, and i mean no offense, but triple check that those eccentric rings are set the same. I know while rushing to change a front belt before my next heat i have put my front end together only to find that one side was at a setting different from the other. This will without question strip belts.
#533
No offense taken... I see your point. I will make sure that those ring are set in the same position(middle)
#537
Originally Posted by THE DOCTOR
Are you guys running the rubber or kevlar belts?
#539
Ran the R today and all I can say is ............Believe the Hype
Better corner entry speed, better exit speed, faster direction changes and rotates very easy without stepping out in the rear. Last time I felt that much difference in a car was when I went from the MRX3 to the MRX4.
Pooh thanks for the setup dude. It was on point, one or two tweaks and it was dialed.
