Mugen MRX-4R
#406
Thanks,
I already did that, front toe was 0 while rear was +2 ( pointing inside ).
Anymore tips ?
Anymore tips ?
#407
Originally Posted by asw7576
When I exit medium tight corners and give it immediate full throttle, the rear tires skid side ways. I have to full throttle quite smoothly ( read : lame, while cars behind my car is preparing to doggy mine ).
Should I increase the length of rear upper arms ? Am I doing correct ? Any other inputs ?
#411
Hi guys, I just switched over from 1/10 touring and never had problems with making the 5min. fuel, what is the best solutions? I already done the following: Changed air filter to the boxed type, reduced ventur.insert to 8-8.5mm, running with gearing:17/49, 20/45 , tires are:66mm and 73mm rear. Checked, and rechecked on all bearing and the car rolled easily. The track is flowing with around 240ft back straight.
What is the next thing to do? Does my driving style can affect that much? barely made 4:50 - 5:05. By the way the RB/c5 engine leaned to almost 260F.
Thanks in adv.
Thanks in adv.
#412
Thanks in adv.
Thanks in adv.
FYI: Runtime issues are quite common in 1/8th scale.
#413
Thanks in adv.
Thanks in adv.
You don't say which exhaust is on your car (this can make a difference), but a 8.5mm insert is quite usual on those engines (don't touch it you could end with a mess of carb adjustment). What can cause a lot of havoc and runtime problems are some manifolds (the conical ones give you more power but at the price of reducing running time).
Your gearing in some cases could be presumably quite short 17/20 is the stock combo, and on a 240Ft backstraight your track will be around 900 to 1100Ft long, you could be more confortable with a 17/21 combo on your tyre sizes (are almost ok, maybe a tad smaller for weekend practice, but ok). Maybe with a 68/75 or 69/76 (stock) you could be happy, use them and save the smaller ones for qualifiers.
You can make more runtime switching to a lesser Nitro content fuel, this will help you in getting some precious seconds of runtime.
Thinking into loud, but some can help you.
#415
Thanks Scott and Corse-R. The pipe: Team CRC power pipe set EFRA No 9902. I guess I am going to lower my nitro content from 30% to 25%. So the next question is would the lower nitro content "mess" my engine up since it was broken in with 30% and so the sleeve and piston already "happy" working together at 30%. The engine has about 1.5 gallon through it.
#416
a lot of guy's are using the 2018 pipe and that yeilds real good mileage. i see quite a few 2031 pipes as well. i have never tried the 2031 so i can't comment on that one.
the change from 30% to 25% will not hurt your engine. you may have to lean your engine slightly as there is less nitro (less oxygen), so less fuel is needed for a given set of conditions.
#417
#418
the 2018 is from RB and Max distrubutes it as well with their markings on it. I believe the 2031 is a JP pipe... again, I'm not sure on the 2031. I just see a lot of them in the pits.
The 2018 is listed on RB's site as a very good mileage pipe. I'm an Intermediate driver and don't have a lot of issues with runtime running the 2018 pipe. A few top driver from my club with runtime issues liked the 2018 as well as it allowed them to make mileage when other pipes did not. We are all running INS boxes and 8.5 restrictors.
it's the last pipe on the page- http://www.rbproducts.com/mainEn.php...oudes_inline21
it comes with the 1351-04 short manifold. It's rated best on their site for mileage, torque and power. I'm sure there are other somewhat better, but this set can be had for $99 dollars most anywhere.
#419
#420
Don't put the shim on the other side. All the shims are put to wheel side.
Make sure the bearings are tucked in ( or plug in ) inside the steering upright correctly.
The wheel hub's pins for rear wheels and front wheels are different in length. Front is shorter.
