Serpent 720
#1126
Originally Posted by Acid
Hi Guys
Has anyone tried the new Team Orion CRF Clutch set for the Serpent 720? This clutch looks like it has weights on it.
Acid
Acid
#1127
1/10 EUROPEAN CHAMPIONSHIP
Top 10 Qualifying positions
1. Michael Salven (D) - S720 - 20 laps in 05:13.5
2. Mark Green (GB) - S720 - 20 laps in 05:20.6
3. Rick Vrielijnck (NL) - MTX4 - 19 laps in 05:01.5
4. Jilles Groskamp (NL) - S720 - 19 laps in 05:02.9
5. Manuel Huber (A) - MTX4 - 19 laps in 05:05.4
6. Martin Christensen (DK) - MTX4 - 19 laps in 05:05.7
7. Julius Kolff (NL) - S720 - 19 laps in 05:06.4
8. Steven Cypers (B) - S720 - 19 laps in 05:06.5
9. Roland Storm (S) - RRRevo - 19 laps in 05:07.1
10.Sebastien Wartelle (F) - RRRevo - 19 laps in 05:07.8
#1128
720 rocks again !!! Congrat to Serpent team..btw I have the same problem with my RCC shocks; crossthread! I manufactured that bottom threaded part from metal and it's perfect now. Pictures;
#1129
This looks impressive. hopefully this ideal goes to serpent..
#1130
Registered User
nice work
#1131
Only a few of the shock included in the first batch of the 720 had that defect. That was because a rushed assembly of the shocks. We are using this shocks since 1 year already without no problem. We just replace the plastic part and we solve it. Contact your LHS or distributor. He should send you some of this plastic parts free of charge
By the way, allu looks nice....but more weigth on the suspension
Paolo
#1132
Originally Posted by Paolo M
Asil,
Paolo
Paolo
this aluminium part locate at the upper halft of the shock not bottom. guess it doesn't make much different.
#1133
Got this from the track. There's an error in the last batch. Go back to your LHS and you'll be helped...
#1134
BTW, what's wrong with the lastic ones? (besides from the crossthread)
#1135
That it boys the Serpent team is rocking all over Da world...
#1136
weight
what is the ideal weight of the 720 i think mine weight like a tank at 1820g, might be because of all the aluminum that i put in the car
#1137
#1138
for sale 720
Hi I have a new 720 in the box 4 sale. The only reason i am selling it is because I am having to much fun with my 960 and can't do both and be good at it. Thats truely the only reason I'am selling it. 399.00
any questions call me Bryon 310-714-1877
#1139
Asil,
Paolo
Paolo
In fact I use RCC shocks for my 710. When you open that lower part for fluid change several times, it's possible to damage that threaded part. For the weight issue you're just right, but you'll be able to change fluid with no fear
BTW, any part # for that part?
#1140
I have done some testing with my 720 yesterday and found that the rear end is very loose for me. I have changed the following from default setup, rear shocks 1.hole, rear roll center is on bottom, no roll bar at all. I'm using 40 outer rear and 37 inner rear tyre, fronts are 40. Any suggestions? Perhaps I can use harder front or softer rear tyres but the fronts wear a little more now and it gets not better. Has anyone try 21t side pulley with 720? I think using 22T 2sp side pulley has the same affect with the 21t mid side pulley, any comment?
