Serpent 720
#4036
anyone know wat the difference is between the red shoe that came in my kit and from the yellow or the black shoes?
#4037
Might be a stupid question but im trying to fully understand clutch end play. Now if u all set ur end play as suggested and u fully assemble ur clutch back together . Say for example im looking at ur car, can i with my hand physically move the bell about in and out about 0.5mm? Im just wondering if my clutch is set wrong all this time. Will explain more when someone answers. thanks!
i set my endplay by putting shims till the bell starts to bind and then i'll remove 0.1mm shim from it and it's good to go!
#4038
The black has good bite but slips a touch and the red is harder and slips more.
The red seems to be more of a hassle to get set right though.
#4039
Apolaro and Serpent 720 win!
Congratulations to DJ Apolaro! DJ driving his Serpent 720, was top qualifier and winner of the A Main at the season opening FORGASS Series Race held at Homestead RC Raceway over the September 13, 14, weekend.
#4041
#4043
Thanks guys,
I will have the race report up on the serpent site soon. Just to let everyone know. The set up I used was the same as always. I did not have to touch my car once. Just lubed the axles and thrust bearing every race.
DJ Apolaro
DJ Apolaro
#4045
Do you have that setup posted somewhere....?
#4046
The Apolaro Report is up on the website:
http://www.serpent.com/news/12575/Th...te-Series.html
Good luck on the nationals DJ...
#4048
I hope this works. Here is my basic set-up for my car. It is very stable. I also add 26grams in my front bumper, run the brass battery tray with the regular battery and the lcg chassis, cut the alum X brace in the middle to have a left and right side. I also cut the left stiffener so it is not using the middle screw.
With high traction I do not use the front sway bar. Good luck to all and please ask if you have any questions.
Regards,
DJ Apolaro
Regards,
DJ Apolaro
