Serpent 720
#3001
#3003
What I am doing after testing the car with all the options is taking one by one out to see if there is a change in the car.
One of the options that have really helped in the handling of the car are:
Serpent 720 Chassis Plate SPP Carbon 803191
Serpent Mono block engine mount LCG M12 303209
Serpent BRASS Battery Tray 803206
VXR LiPO LRX-211000 - Receiver Packs - Li-Po, 1000 mAh
I do have more options install but this ones has really help, lowering the engine to 1.5mm, lowering the tank with the installation of the LiPo Battery to near 3mm and increasing the wait in the middle of the car with the brass tray, really has eliminated the traction roll in fast turns, etc.
RCPANAMA
#3004
Hi .
I'm wondering if anyone has had a problem with slop ( movement ) in the rear hinge pins . I can slide the rear arms about 1.5 mm backwards & forwards on the pin . Could it be the inserts ? Or should i replace the arms ?
I have only ran the car for 5 race day's .
Any suggestions on what else i can do would be welcomed
Regards Paul
Regards Paul
#3005
Hi .
Regards Paul
Regards Paul
for the slop.
Part No.:#1094
#3006
#3007
If you bay the LiPo I use, you have to make some changes in the Battery Plate I had to do the same with the brass plate, I herd Serpent is coming with a LiPo that will fit the Battery Plate, but I am including the photo of how I did the change (Had to cut the side of the plate)
http://www.rctech.net/forum/attachme...4&d=1154611302
RCPANAMA
#3010
Hi .
Regards Paul
Regards Paul
#3011
Just wanted to drop in and thank Maxy, Gianni and DJ for the support at this weekends US open fuel Sedan champs. With your help my car was really good for the mains. Just a bit of bad luck but I had a blast. Look forward to seeing you guys next year at the Capitol Classic. Would like to make it to the winternats but the wife would probably kill me....LOL.
Gael
Gael
#3012
Stable Setup
Setting up a new 720 for my 11 year old son, looking for a stable easy to drive setup - not a fast setup! Is the stock Serpent recommendations on the instruction manual a good place to start or is there a better setup to start with. We are both new at this so any help would be appreciated. One more question: Which Glow Plug should I use to break this engine in (JL Red Dot/ Maxy's 20% nitro) Running in SW Florida (Warm and High Humidity). Nitro House recommended PICCO hot plug with hot filament (Will this hurt my engine?)
Fishing Fool
Serpent 720
JL Red dot
Maxy's 20%
M11
Fishing Fool
Serpent 720
JL Red dot
Maxy's 20%
M11
#3013
Fishing Fool
Serpent 720
JL Red dot
Maxy's 20%
M11
Fishing Fool
Serpent 720
JL Red dot
Maxy's 20%
M11
#3014
Fishing Fool
Serpent 720
JL Red dot
Maxy's 20%
M11
Fishing Fool
Serpent 720
JL Red dot
Maxy's 20%
M11
#3015
I hope to be running in the Forgass series starting at the Punta Gorda track in the near future. We will also be running on a very short-technical track in Englewood, Fl to get more driving time in for my son. I have two 720's that I can set up identical or different for each track. Thanks for your help!
