Serpent 720
#2147
Originally Posted by neltime64
Has anyone ever run the Serpent truck body (#170027) and does anyone know of any store that stock these in U.S.?
We're thinking about starting a class with these at our track.
#2148
Originally Posted by lil-bump
My indoor(nitro) club ran this class. (Toro truck class). All I can say it is a blast to drive. The body has a ton of front downforce. But the rear has little to none. The turn in is outragious but you can't get on throttle to early or the rear end will rotate on you. You have to practice keeping the rearend behind the front Cab.
With the dutch nitro tour we used this body too, remove the rear stabi, helps lots! When there's grip enough, you can put the stabi back on...
It was actually quite fun, because we had 1 heat anti-clockwize, and that gives wrong grip levels on some corners, you could go tipsy just because you where of the line and then got on it
#2149
Our track was set up as a mild road course (one slow s-turn) but as a rule no rear stabalizer could be used
#2150
The 720 has a staggering 76 option parts available for it. I'm wondering what everyone is actually using on their cars and what the most common upgrades are.
Also, what engines and pipes are the Team guys using? I'm adding an engines section to the KB and it would great if I could list exactly what each person is using, both here in the US and abroad, to help answer the question "What engine/pipe should I get?"
Thanks!
Paolo: Mega MF 12 / 2602
Thanks!
#2151
Originally Posted by Racer Z
Wow what a statement. Serpent cares about us!! sorry I mean this
#2152
Originally Posted by captian
#2154
Thanks!
Thanks!
#2155
Mentioned upgrades to the 720..
I have: Installed the new gas cap, put in the break one way bearing shaft, put in titanium piviot balls (710 & 720), blade type rear swaybar (720), Aluminum mid bearing brace, CVD's all around. Did some other upgrades to ghetto proof my 710 when racing on small parking lot tracks.
720 is loaded for 301! I'm hunting Mugens!!
#2156
Originally Posted by Killa G
Jimmy knows what I am talking about. We are surrounded by Mugens. But the # of Serpent's is picking up.
#2157
We will be in full force at 301 this year.
#2158
One thing that was clearly obvious, as I went through all 72 pages of this thread (for the second time), is that the Team Serpent guys provides great support for the 720 here in the forum. You won't find this level of vigilance and customer support in some of the other threads.
Cheers!
Rainer
Cheers!
Rainer
Thanks Julius
#2159
Location: Costa Del Sol, Marbella, Spain www.bradir.net
race
FRIDAY NIGHT RACE WITH MR JULIUS KOLFF
AT JP RACEWAY PHILIPPINES MARCH 16 2007
HERE'S A PREVIEW
http://www.dailymotion.com/ianhobbie...way-mar-16-200
see you at the next race julius! thank you!
from all the guys at RCMP
HERE'S A PREVIEW
#2160
Thanks!
Thanks!
