Serpent 720
#1726
Originally Posted by B4
Has anyone seen these at any online shops yet.
803191 Chassis Plate 720 SPP Carbon
803197 Bumper foam 710/720 wide
803192 Servo Saver set adj. Ackerman 720
803171 Body-support set RR floating
803180 Rear body brace SPP
Anways, the chassis plate is a preorder since it won't be out until the mid of January. I tried the adjustable servo saver tonight and it is sweet! It has 4 settings. I basically started with the long version of the stock configuration. I haven't tried all of them but of course the longer has the best initial entry. I can't wait to get the new bumper and the new chassis .
#1727
Originally Posted by Jo Gutierrez
Try The Border RC. They get the new stuff right away because they are in the Serpent country.
#1728
Originally Posted by redsand
I like to use a camber gauge to set the initial camber bofore running the car. Then after a few laps, check the tires to see which corner end needs more or less camber and adjust accordingly.
Hope it gets rid of the problem - different settings when using the setup system and using the camber gauge....
Acid
#1729
#1730
Originally Posted by eduardo_garcia
Does it fit on the 720?
(803192 Servo Saver set adj. Ackerman 720)
#1731
I checked the website (Border) and they do not have any parts from Skyline Racing there
Acid
#1732
Originally Posted by Acid
Hey Jo
Acid
Acid
#1733
Hey Jo
Acid
Acid
I don't think the Border is a Skyline distributor (yet)... Anyways, buboy is right. You can go directly to the Skyline website or other online hobby shops mentioned above.
#1735
Just wanted to let you know that the new chassis is available in HK, mine is on the way already.
#1736
Ball Race Diff
Would anybody have an exploded assembly view for a Serpent 720 Ball Race Diff ?. Thanks Klj..
#1737
You can find the ball diff assembly instructions for the 710 here in the 710 downloads section if thats any help to you.
http://serpent.com/product/802000/downloads/
#1738
Originally Posted by ioxqq
The new chassis is at rc-mushroom
http://rc-mushroom.com/product_info....ducts_id=12064
#1740
A convert...
Well I finally got a serpent 720, truth Serpent got this one right. To be honest I do not miss my Kyosho. I found the car very stable and easy to drive. Special thanks to Roniel for building the car and Dj for the help with setup.
