Serpent 720
#1666
Originally Posted by Jo Gutierrez
This chassis looks awesome. Info is available at mytsn.com
I just saw it today... I sure want one for Christmas .
I have looked for this on mytsn.com and didn't find anything? Is this for the 720 as well?
Acid
#1667
It is only for the 720, look under products in the web site
#1668
Acid
Yes, the chassis is for 720. I don't know why it's not on mytsn at the moment as I got the info from the same website originally 2 days ago.
#1669
Acid
Hi
Yeah, I couldn't find it there
Acid
#1670
This item is not due out for a while. It was to be posted on the distributor part of the site as a pending product but was accidently listed in the public side of the site. Serpent found their mistake and corrected it. Not to fear, it will be back but closer to the time it's ready to ship.
#1671
rpoage
Thanks man, that's good to hear that it will be available.
Nigel
Since the new chassis is not available yet, you may choose some other great Serpent products as a Christmas gift for me. I will not be picky . Your Dad has my address .
Nigel
#1672
rpoage
Nigel
Nigel
#1673
body posts
Does anyone know if the front body post position is the same on the 720 as the 710 ?
#1675
Originally Posted by Team Kamikaze
Yes, they are identical
#1676
someone prepared list of interchangeble parts here in this forum;
thanks for him again...
All Centax 3 parts
All 2speed parts (except the alxle, as the flat spot for the side pulley is different)
Front diff (both gear and ball)
Rear diff steel parts (only the pulley is changed, so for the gear diff you'll only need a new case, and the ball diff a new pulley)
All belts
All bearings
Middle x-brace (alu)
Middle bearing block (alu and nylon)
Mid axle
Battery holder and attachment points.
Fuel tank and holders
Body posts
Springs
Drive shafts
Wheel axles
CVD's
Steering blocks
Front upper wishbone
Caster clips
Servo saver parts EXCEPT THE lower plastic part which now has a countersunk screw!
Engine mount (both 2 peice and monoblock)
Front sway bar (holders and sway bar itself)
Brake rotor and pads
Brake excenter
All Centax 3 parts
All belts
All bearings
Mid axle
Body posts
Springs
Drive shafts
Wheel axles
CVD's
Steering blocks
Caster clips
Brake excenter
#1678
Actually, the main shaft from the 720 works on the 710, but not vice versa.
#1679
Weight Distribution
Hi Guys
Has anyone used extra weight on their 720 to try and balance their car? Or used a digital weight distribution system?
If you have, did you purchase a system or is there another way of doing this?
Can anyone help?
Acid
Can anyone help?
Acid
#1680
Originally Posted by Acid
Hi Guys
Can anyone help?
Acid
Can anyone help?
Acid
