Old 03-29-2006, 03:07 PM   #1
mt12ob4's Avatar
Default JUST SOME QUESTIONS--
Hey, im new to the site-i recently picked up an ofna ob4-slim line and ive become quite familiar with it already-i managed to swap a nova mogen mt12 engine-its running with a two speed-great performance! Just a quick question, my engine seems to heat up to about 350-400*F within a tank. Anyone know what i should do to make it run better-its already running pretty rich?????
Also-just picked up the RPM camber gage- what do you guys recomend for the front and rear tires?
Thanks.
mt12ob4 is offline   Reply With Quote
Old 03-29-2006, 03:34 PM   #2
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Thanks.
First off I think your motor is running way too hot try to keep temps in the 200 and up when driving it also go over to the engine thread and ask some questions about this particular motor someone will be able to help you.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 03-29-2006, 05:18 PM   #3
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
350-400 it would be blowing up or not lasting long.
Are you sure its running that temp? I see canada in the sig so your probably used to C.
You can goto google and type in 123C to F and it will convert it to whatever your running or just post what you know its running to C. Otherwise dont run that motor again until you get it worked out or your going to blow it at those high temperatures.
400F = 204C. You should be running 240F = 115C , thats about the right range. Maximum I would ever allow would be 270F = 132C.
Artificial-I is offline   Reply With Quote
Old 03-29-2006, 07:27 PM   #4
mt12ob4's Avatar
Thumbs up
alright thanks guys-youve been a great help-i just found out that i should probally run it a little more richer since the weather is getting alot better-ill try it out- see what happened and keep you guys posted-thanks agian.
Old 03-30-2006, 12:07 PM   #5
Moderator
Yeah theres two needles one of them is way off or your running rc plane fuel or something weird.
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-11-2008 12:03 AM
B4: Kit vs RTR, Questions. BelialX13 Rookie Zone 15 02-14-2008 04:57 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 02:19 PM
TNX QUESTIONS chrometwanks Monster Trucks 2 02-03-2006 06:02 PM
TB questions nekmiyevo2 Electric On-Road 7 08-11-2005 09:37 AM
