HPI Trophy 3.5 V2 Problems >
Old 01-28-2017 | 05:57 PM
Default HPI Trophy 3.5 V2 Problems
So I recently purchased this buggy and to get it to run for the break in procedure I had to have the HSN and lsn right much richer than break in settings (both flush) with the carb opening set way less than 1mm, almost closed.
So I assumed I had an air leak but continued with break in since I had some raw fuel spitting out of the exhaust, before tearing it down to sealed it up.
I also checked the needle o-rings and they look to be fine.
Now here's the current issue...
When tuning for performance the only balance I can seem to get between off the line and top speed is with the lsn 1 -1.5 turns richer than flush and HSN about 2 turns lean from flush. Which to me whatever runs best doesn't bother me where it's set, just giving as much info as possible.
So I can tell the engine isn't reaching top speed/rpms, it just kind of lays flat at the very top end. 1/8 - 1/4 turn lean on HSN from here I get lean cut-out, 1/8 - 1/4 turn rich and I get even more reduction in speed/rpm. Idle lays down good, smooth, and stable so i havent been messing with the lsn.
Tryed the stock hpi R5, o.s. #8 & #9, and McCoy Mc9 glow plugs without affect. Which I do know they're similar ranges.
Nothing in drive train is in a bind, it'll roll forever.
Also no fuel/oil coming out from the front bearing.
Sorry for the long post, didn't want to say hey I can't get my car tuned.
What can i do next??
XtremeJDM is offline
Old 01-29-2017 | 12:33 AM
Your plugs might be way too cold unless you're running in really hot weather. Try a P3 plug from O.S or Protek. I'm assuming that engine takes a turbo plug. If not turbo, then whatever the hotter version plug is that fits that engine.
My ST-RR EVO is offline
Old 01-29-2017 | 06:05 PM
Went back to tuning with the os #8 instead of the stock hpi cold plug, got SLIGHTLY better performance but still can hear it being limited in upper rpm.
I hope it's just not just the way this engine is. I know it's not a race mill, but the 2.5 in my rustler screams compared to this thing, by sound.
Seems to have adequate pinch & running vp 20% master basher
Edit: going to try a traxxas long reach plug to up the compression just to see, calculations shows enough clearance not to worry
