Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#1171
So i have the aluminum hub carriers and even putting a small spacer theres wobble in then? I just put new arms thinking they were wobbled out but that wasnt the case as it still does the same thing with new arms? Should i another shim or replace the busings on aluminum hubs? This is for the front!
as mourinho said this car is better with a little wobble....remember we are off road not on road lol
#1172
I use superglue. Bushing seldom vear out. If you need to change them, boil :-)
#1174
Thanks everyone i will replace the bushings and try shoegoo
#1179
I took apart the front diff only to find out that the gears have been damaged after one hour since the initial run of the new kit.Diff oil looked like liquid metal.No,I have not set the gears the wrong way.Are these cars so fragile?? So many durability issues one after another.
#1181
#1182
the internal gears being aluminium can look in poor shape but in fact that is normal, also the oil does turn metallic black color after about an hour of use, again not a problem. i replace oils after 2 race days.
a while back i think it was tebo did a diff video, he talked about the chipped surface of gears and confirmed its not a problem.
honestly these diffs are amazing, they never leak, gears last for a long long time, largest oil volume diffs of all brands and they stay super consistent during long mains
#1183
do you have a picture of the damage? if your talking about small surface chips then that is normal and you can continue running them.
#1184
when they are new is when the diffs are most notchy.
my current gearset in one of my cars is over a year old and is splendid to drive.
#1185
