TLR 8ight 4.0
#1006
I did the setup changes yesterday in my ebuggy(weren't enough nitros) and the car was great! Much easier to drive and tons of rear grip without losing steering.
#1011
So, they are coming as new optional part? Many we don't have to modify? May I know the part number? Thanks
#1013
Will the old optional at the time 2.0 buggy adjustable hinge pin blocks work on the rear!? I swear its hrc, nothing written on it, if someone knows that'd be awesome, gunna try it out if that's the case.
#1017
PRO TIP FROM A PRIVATEER
For anyone who likes to run full droop on their buggies you may notice the spindle carrier touches the arm and can result in the spindle carrier cracking as shown in the last picture. The reason we run full droop is that we feel it gives the car more grip/traction on lower traction outdoor tracks.
So back to the issue. First off you will want to use a silver sharpie and trace where the caster block is touching the arm. Next take the spindle and carrier off of the arm. You will take a drum style dremel and dremel out the area at a 45 degree angle to the arm. Test fit, if the carrier is still touching take a little more material off. Put the carrier back on the arm and you should see space between the carrier and arm as pictured.
Hope this helps! I will be headed down to PNB this weekend, see you guys there!
#1018
Got the ADI plate and it fit perfect. The pills fit perfect as well just like the TLR LRC plate. It also has the tab that fits in the hole of the chassis. Thanks for the recomendation Maddog.
I also took out the droop screws on the rear for full droop and modified the front a-arms for the caster to clear. And thanks for that info Maddog. :-)
Can't try the new changes because our local track is being maintanace until the 15th.
#1019
Yeah its different to the lrc plate side by side, awesome news, keen to see how it'll go, thanks for your input fellas.
#1020
