Kyosho MP777 SP2 Thread
#646
My friend that did the swap said it helped out alot for him.
This is my turn just getting back with the Kyosho after about a 2yr break from racing. I got a Losi 8ight and raced for about 4mos(total of 5 races IIRC) and the decided to go back to the Kyosho.
I went 55wt(Trinity) in front and 40wt(Trinity) in rear. The rear does feel abit more dampened so I will try the other pistons as recommended down the road.
#647
Ran the Cody King set up this weekend with minor tweaking.
5F 6C 2.5R
55W Trinity Front Shock
40W Trinity Rear Shock
TQ'd and won the main. For my style, I like the Kyosho over the Losi 8ight.
Had real good turn and was pretty stable.
I like the WC edition with the Big Bore shocks.
Got it all cleaned up and new fluids again to be ready for RC Pro Series in two weekends.
5F 6C 2.5R
#648
BIG BORES
i wanna big bore my sp2 out where is the best place to buy them as a set? al 4? or is it rear and front? i want a complete set ready to slap on any part numbers would be very helpful.....i really need to get this done my sp2 right now with the stockers fells like soft pillow one of the guys at my local track asked me if i even had fluids in them im running 65 front 45 rear because there so weak and there still weak...Help help help
#649
Check the typical online shops.
www.amainhobbies.com
www.tiltedrc.com
www.carolinasrc.com
I dont know part numbers but you need to complete a buggy:
Front
shock kit
springs
stand offs
lightened universals
Rear
shock kit
spring s
stand off
www.tiltedrc.com
www.carolinasrc.com
Front
shock kit
springs
stand offs
Rear
shock kit
spring s
stand off
#650
Big bore shock kit front- KYOIF349 Front springs-KYOIF350-716 Rear-KYOIF346 Springs- KYOIF348-1116 Stand Offs-KYOIF346-04 Front universals-KYOIFW333 Rear-KYOIFW334 Center-KYOIFW335
#651
UNIVERSALS
why do u need to change your front and rear universals? and i really appreciate all the part numbers posted to complete the set up!!!!!!!
#652
#653
wow
282.00 to convert to big bores yikes why the front and rear and center universal changes?
#654
In Europe (Denmark to be specific) the Kyosho Big Bores are very expensive. Therefore alot use the big bores from Nanda. They fit perfectly and according to all the people I've heard, work just as well. The Nanda big bores are 1/4 the price of the Kyosho's in Denmark. Happy Hunting.
#657
The new universals are lighter than the orignal universals, the front will rub at times, there really is'nt much clearance. They are also much stronger than the orignal universals. Chrome moly.
#658
RUBBING
if i dont need to change the uni's i wont i mean sheeesh the shock kits themselves are expensive,so can anyone confirm they wont hurt if u dont change your universals out back and front?????
#660
I have had mine hit just a little on the spring, the backs are fine, with all thats said about the big bores and the universals,the big bores will make a ton of difference over the stock originals, besides the universals being lighter, it's less rotating mass, which in turn will be less weight, more responsive, stronger, and they sure look bitchen also.
