problem with brake sticking
my dbx 2.0 is all good to go, except for one small problem
braking works great
but when I open the throttle, the brake lever doesn't disengage, it just stays put
perhaps I'm wrong, I really have no experience with nitro, but I think the brake level is supposed to move with the arm, kinda like this
am I maybe missing a spring that's supposed to go there?
braking works great
Take a ballpoint pen. Get the spring out and cut it in small lengths. Maybe 2-3mm? Maybe longer. Put these on the screws that hold the brake pads in between the two pads. These will help keep your brakes from dragging when you don't want them.
Your motor will be a tuning nightmare without a carb boot. Plus suck in all the dust/dirt.
put a spring in between the arm and the tubing you have on there. that way it will push it out.
I just took some fuel line and put it on the arm, works like a charm
a spring would have done the same thing
is there a diy for carb boots? I know you can use balloon animal balloons for shock boots
oh, well thanks for the info for future reference!
I've always done electric, so seeing the other side of things with nitro, I understand the appeal now, and I'm sure this won't be my last nitro car
