jato 3.3 shuts off if i hit the gas help pleas
hey every one i have a new jato 3.3 its new right out the box i had this problem.turns on sounds good but as soon as i hit the gas it shuts of, i lean the carb a little see if it fix but no. did the hole carb reset same proble.only way i can get it to run if i leave the ez starter on as i push the gas. any info will help thanmks yall . its like 65f in dallas
ok i will try that
When the engine is new and running rich it will bog down when you try and run it and die... often. Especially if your not used to it. Be patient. Keep your starter box and glow ignitor (charged) handy b/c your engine will probably die and need to be restarted a bunch of times. Like Hoese37 said, lean the needles 1/8 of a turn. Be prepared to turn them in more than that as well in small incriments (like a 1/8 turn at a time). The other thing that helps when its rich is that you can rev the throttle quickly. This helps to clear out the engine so it won't die. If you just give the trigger one pull to full throttle, it'll just overdose on fuel and die. Once the engine is broken in and leaned out just right, that won't be nearly as much of an issue.
thanks guys i change the glow plug and leaned it a little and it works like a champ no wheelies yet need to work on the tuning
