Xray XB8
#3706
So i picked up a parts lot for my xb8. Its come with a set of crown wheels @ 40t. Just wondering what the advantage would be to run the 40t instead of the 46t.
My track is a small/medium 8th scale track. Lots of sharp turns and medium sized jumps. It grooves up but is a bit loose.
Cheers.
Cheers.
#3707
Yes, I understand that you measure using a setup system. But my question what do you measure. With the angle of the XB8’16 STEERING BLOCK to what do you subtract anything?
Below is a picture of my setup:
Attachment 1434157
is it 20 - 30%
Attachment 1434157
is it 20 - 30%
#3708
#3709
Anyone know if the d817 proline predator body with fit the xb8 2017?
#3711
Anyone in here used the Bittydesign Force body for the XB8 on the 2014 and 2017 XB8?
Bittydesign. Force Clear body for Xray XB8
#3712
#3713
#3714
#3716
#3717
R/C Tech Elite Member
Did another rebuild on my XB8, can't help but take pics of it every time I tear it down and clean it up/replace things. They are just damn good looking buggies.
Xb8 rebuild. by Jeremy Sensing, on Flickr
#3718
Cheers.
Cheers.
both these combined are the underdrive option for the rear (rear only i emphasize). they will slow down the rear wheels rotation when compared with the front. this means the car will pull more from the front and is tended to be used in loose conditions.
#3719
